Problem with audio not coming directly in bluetooth headphones
Ok so I recently switched to garuda from windows. At first everything was fine but now my headphone doesnt play the audio playing. The only temporary way to fix this is to go to audio volume in the taskbar and select Play all audio from this device. But this also reverts back when a pause the audio for a few seconds. I am using garuda dragonised gaming version. Sorry for my bad grammer.
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=8f5d6e1d-a90b-4178-8a83-9f7ae0756445 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 81HN v: Lenovo V130-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo V130-15IKB
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 8VCN17WW date: 05/02/2019
ID-1: BAT0 charge: 8.0 Wh (32.1%) condition: 24.9/30.6 Wh (81.2%)
volts: 8.1 min: 7.6 model: CPT-COS L17C2PB3 type: Li-poly serial: <filter>
status: charging
Info: model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2300 min/max: 400/2300 scaling: driver: intel_pstate
governor: performance cores: 1: 2300 2: 2300 3: 2300 4: 2300
bogomips: 18399
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 5986:2113 class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15db built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Sound Server-1: ALSA v: k5.18.15-zen1-2-zen running: yes
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:3166 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.03 TiB used: 65.71 GiB (6.3%)
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LFM1
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung
model: MZ7LH128HBHQ-000L1 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1.14 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 65.71 GiB
(55.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 65.71
GiB (55.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 65.71
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 65.71
ID-1: swap-1 type: zram size: 3.18 GiB used: 744.2 MiB (22.9%)
System Temperatures: cpu: 53.0 C pch: 47.0 C mobo: N/A
Processes: 220 Uptime: 22m wakeups: 1 Memory: 3.18 GiB used: 2.37 GiB
(74.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: 1820 pacman: 1813 lib: 514 snap: 7
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.5-1):
System install date:     2022-08-05
Last full system update: 2022-08-05
What changed between it working and not working?
Whenever you experience a Bluetooth issue after an update, check to see if the kernel was updated. If so, be sure to test alternate kernels starting with the linux-lts kernel.
Maybe this is a brand new installation and still needs a garuda-update?
Ok so i saw that my system was not updated and i updated it using garuda-update and also installed the linux-lts kernel. But the situation is still the same and nothing has changed. Maybe my headphone isnt the default audio player and thats why the sound only comes when click on play all sound through this device.
i AM facing the same issue and my earphones are not faluty they are working on other devices , please help my workflow has stopped without earphones as my speakers are broken and bluetooth was the only way for me to connect to my laptop
Please open a new topic.
This one is almost one year old and too many things changed since that time, as normal for rolling releases.
Please make sure to provide all the information requested in the template (garuda-inxi, things you've already tried, etc.).
I'm going to close this one.
