Hello everyone !
I’m really new on linux and it’s really cool to learn everyday, exciting experience ! But i’ve so many trouble with my meta quest 3s and ALVR for Steam link connection, I really want to delet for ever my windows on my pc but still needed till Iven’t solve this problem
I’ve tried so many different options, that’s why i’m posting here, my last hope…
So when I connect the headset on my ALVR it’s stuck in a loop of disconnection, i’ve tried very different version of ALVR, the matching option with the version on m’y headset still give the bests results but doesn’t work
Si what do you need and how can I give you to help me ? I’m on garuda linux NVIDIA version
Thanks a lot by anticipation, I’m desperate… (Want to play phasmophobia VR so hard haha)
EDIT 2 :
I’ve tried to upgrade my garuda, to allow the firewall rule, i’ve tried without the rule and without the firewall active
And i’ve tried to run ALVR on so many versions, nightly and stables
I’ve read that some issues will be caused by pipewire and then i’ve desactivated the audio and microphone microphone
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f72c5f2d-8e42-4666-9a0f-03f0334b9445 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx
UEFI: American Megatrends v: 0607 date: 05/29/2020
Info: model: Intel Core i9-10850K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 10 cores: 10 threads: 20 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB
desc: 10x256 KiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 3037 min/max: 800/5200 scaling: driver: intel_pstate
governor: powersave cores: 1: 3037 2: 3037 3: 3037 4: 3037 5: 3037 6: 3037
7: 3037 8: 3037 9: 3037 10: 3037 11: 3037 12: 3037 13: 3037 14: 3037
15: 3037 16: 3037 17: 3037 18: 3037 19: 3037 20: 3037 bogomips: 144000
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: eVga.com.
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,DP-3 empty: DP-2,DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1b82 class-ID: 0300
d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 3440x1440 size: N/A modes: N/A
Monitor-2: DP-3 pos: top-right res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1070 Ti driver: nvidia v: 565.57.01 device-ID: 10de:1b82
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8)
Device-2: NVIDIA GP104 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Razer USA Kraken V3 HyperSense
lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 1532:0533 class-ID: 0300
Device-4: Shure MV7 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 14ed:1012
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
Device-2: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:07b1
class-ID: 0200 temp: 67.7 C
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
Info: services: NetworkManager, smbd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 12.73 TiB used: 366.79 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWR11A size: 9.1 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 0603 scheme: GPT
ID-1: / raw-size: 2.54 TiB size: 2.54 TiB (100.00%) used: 366.75 GiB (14.1%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 45.2 MiB (47.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 2.54 TiB size: 2.54 TiB (100.00%)
used: 366.75 GiB (14.1%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 2.54 TiB size: 2.54 TiB (100.00%)
ID-5: /var/tmp raw-size: 2.54 TiB size: 2.54 TiB (100.00%)
ID-1: swap-1 type: zram size: 125.67 GiB used: 9.7 MiB (0.0%)
max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 39.0 C mobo: N/A
Memory: total: 128 GiB note: est. available: 125.67 GiB
used: 4.58 GiB (3.6%)
Processes: 449 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.21 GiB services: org_kde_powerdevil,
Packages: 1745 pm: pacman pkgs: 1725 libs: 491 tools: octopi,paru
pm: flatpak pkgs: 20 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-09-12
Last full system update: 2024-11-27
