Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3e9d67f3-9fab-44f2-a900-c1632fc7b44c rw rootflags=subvol=@
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: A320M Pro4-F serial: <superuser required>
UEFI: American Megatrends v: P2.20 date: 07/27/2020
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3715 high: 3881 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3113 2: 3778
3: 3816 4: 3606 5: 3881 6: 3807 7: 3868 8: 3853 bogomips: 57490
Device-1: AMD Baffin [Radeon RX 550 640SP / RX 560/560X] driver: amdgpu
v: kernel bus-ID: 06:00.0 chip-ID: 1002:67ff class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 driver: loaded: amdgpu,ati
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: AMD Radeon RX 550 Series (POLARIS11 DRM 3.44.0
5.16.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:aae0
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.04 TiB used: 153.83 GiB (7.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
type: SSD serial: <filter> rev: 0615 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000VN004-2E4164
type: HDD rpm: 5900 serial: <filter> rev: SC60 scheme: GPT
ID-1: / raw-size: 222.59 GiB size: 222.59 GiB (100.00%)
used: 8.5 GiB (3.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
used: 145.33 GiB (7.8%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-4: /var/log raw-size: 222.59 GiB size: 222.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 222.59 GiB size: 222.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 332 Uptime: 8m wakeups: 0 Memory: 15.55 GiB
used: 2.32 GiB (14.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1292 lib: 351 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Hi. After update of Garuda this morning, Alacritty gives error message.
[0.000323842s] [WARN ] [alacritty_config_derive] Config warning: background_opacity is deprecated; use window.opacity instead
Thanks in advance.
I did not changed anything in config.
