╭─alnone@alnone in ~ took 7ms
╰─λ LANG=C paru -Syu
[sudo] password for alnone:
garuda is up to date
core is up to date
extra 8.4 MiB 5.22 MiB/s 00:02 [----------------------] 100%
multilib is up to date
chaotic-aur 2.5 MiB 1492 KiB/s 00:02 [----------------------] 100%
there is nothing to do
:: Looking for PKGBUILD upgrades...
:: Looking for AUR upgrades...
:: Looking for devel upgrades...
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
Aur (1) Old Version New Version Make Only
aur/yandex-browser 24.1.1.940-1 24.1.1.940-2 No
:: Proceed to review? [Y/n]: Y
:: Downloading PKGBUILDs...
PKGBUILDs up to date
/home/alnone/.cache/paru/clone/yandex-browser/PKGBUILD
# Maintainer: Mikhail Velichko <efklid@gmail.com>
_pkgname=browser-stable
pkgname=yandex-browser
pkgver=24.1.1.940
_pkgver=24.1.1.940-1
pkgrel=2
#epoch=1
pkgdesc="The web browser from Yandex.
Yandex Browser is a browser that combines a minimal design with sophisticated >
arch=("x86_64")
url='https://browser.yandex.com/'
license=("custom:yandex-browser")
categories=("network")
provides=(yandex-browser)
conflicts=('yandex-browser' 'yandex-browser-stable')
depends=( "binutils" "ttf-liberation" "jq" "alsa-lib" "at-spi2-atk" "libcups" ">
"wayland" "libxcomposite" "libxdamage" "libxkbcommon" "libxkbfile" "libxrandr" >
optdepends=(
"speech-dispatcher"
─alnone@alnone in ~ took 10ms
╰─λ inxi -Faz
Kernel: 6.6.22-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=91c0a886-25fe-452a-b52b-00f0e5b90cbe rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: Inspiron 3583 v: N/A
Mobo: Dell model: 0WHCP7 v: A00 serial: <superuser required> part-nu: 08CA
uuid: <superuser required> UEFI: Dell v: 1.5.1 date: 05/30/2019
ID-1: BAT0 charge: 39.9 Wh (100.0%) condition: 39.9/42.0 Wh (95.0%)
volts: 12.5 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
stepping: 0xC (12) microcode: 0xFA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 988 high: 1959 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1959 2: 800 3: 1174
4: 400 5: 400 6: 1573 7: 800 8: 804 bogomips: 28808
Type: gather_data_sampling mitigation: Microcode
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5520
Display: x11 server: X.Org v: 21.1.11 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2017 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.0.3-arch1.1
device-ID: 8086:3ea0 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.22-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 10.05 GiB (4.2%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20200012 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
used: 10.02 GiB (20.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 1.43 GiB size: 1.43 GiB (99.80%)
used: 27.7 MiB (1.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
ID-4: /var/log raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
ID-1: swap-1 type: partition size: 1.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C pch: 43.0 C mobo: 36.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 8 GiB available: 7.63 GiB used: 1.89 GiB (24.8%)
Processes: 259 Power: uptime: 1h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1453 libs: 430 tools: octopi,paru,yay
pm: flatpak pkgs: 0 Compilers: gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
╭─alnone@alnone in ~ took 1s
╰─λ
filo
17 March 2024 23:03
2
What is the problem?
You have to exit from the PKGBUILD preview with button q.
Sorry, i forgot yay outcome:
╰─λ LANG=C yay -Syu
core is up to date
extra is up to date
chaotic-aur is up to date
:: Searching AUR for updates...
:: Searching databases for updates...
:: 1 package to upgrade/install.
1 aur/yandex-browser 24.1.1.940-1 -> 24.1.1.940-2
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
-> Excluding packages may cause partial upgrades and break systems
AUR Dependency (1): yandex-browser-24.1.1.940-2
:: PKGBUILD up to date, skipping download: yandex-browser
1 yandex-browser (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> A
:: Deleting (1/1): /home/alnone/.cache/yay/yandex-browser
HEAD is now at 0fb35df Remove wrong debug option
Removing src/
Removing yandex-browser-24.1.1.940-1.deb
==> Diffs to show?
==> N
==> Making package: yandex-browser 24.1.1.940-2 (Sun 17 Mar 2024 07:00:39 PM EDT)
==> Retrieving sources...
-> Downloading yandex-browser-24.1.1.940-1.deb...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 153M 100 153M 0 0 210k 0 0:12:26 0:12:26 --:--:-- 202k
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with sha256sums...
yandex-browser-24.1.1.940-1.deb ... Passed
:: (1/1) Parsing SRCINFO: yandex-browser
==> Making package: yandex-browser 24.1.1.940-2 (Sun 17 Mar 2024 07:13:06 PM EDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
-> Found yandex-browser-24.1.1.940-1.deb
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Extracting yandex-browser-24.1.1.940-1.deb with bsdtar
==> Starting prepare()...
==> Sources are ready.
==> ERROR: Cannot find the debugedit binary required for including source files in debug packages.
-> error making: yandex-browser-exit status 15
-> Failed to install the following packages. Manual intervention is required:
yandex-browser - exit status 15
╭─alnone@alnone in ~ took 13m15s
hope i’m not saying anything wrong now, install debugedit then it should work with yandex
sudo pacman -S debugedit && upd -a
filo
18 March 2024 05:41
5
This is probably a yay problem not a yandex one.
It should be due to the recent pacman update. See
opened 01:19PM - 13 Mar 24 UTC
closed 04:27PM - 13 Mar 24 UTC
Type: Bug
Status: Resolved
yay: error while loading shared libraries: libalpm.so.13: cannot open shared obj… ect file: No such file or directory
https://aur.archlinux.org/packages/yay-git (so think you need to update your package to use the new version of libalpm
yay fails with the new pacman 6.1 thats now in testing on Arch Linux: https://archlinux.org/packages/core-testing/x86_64/pacman/
Uninstall and rebuild it.
buccaneer78:
debugedit
any way, it is safe to install ‘debugedit’?
filo
18 March 2024 12:05
7
Yes, absolutely safe.
It is in the Arch Core repo, so if you/we don’t trust it, we should trust Arch altogether
But I still believe it is a matter of uninstalling and git cloning and making yay…
Even when I wrote the ‘LANG=C’ some parts are in spanish, so this was at the end of the outcme:
(1/7) Arming ConditionNeedsUpdate...
(2/7) Foreign/AUR package notification
(3/7) Orphaned package notification...
libxnvctrl 550.54.14-1
poppler-qt5 24.03.0-1
(4/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/passwd.pacnew
/etc/locale.gen.pacnew
/etc/updatedb.conf.pacsave
Please check and merge
(5/7) Updating the desktop file MIME type cache...
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 152
(7/7) Syncing all file systems...
System updated! 🐧
╭─alnone@alnone in ~ took 12m24s
╰─λ
In case any body want to see the whole …
╭─alnone@alnone in ~ took 11ms
╰─λ LANG=C sudo pacman -S debugedit && upd -a
resolving dependencies...
Package (1) New Version Net Change Download Size
core/debugedit 5.0-5 0.10 MiB 0.04 MiB
Total Download Size: 0.04 MiB
Total Installed Size: 0.10 MiB
:: Retrieving packages...
debugedit-5.0-5-... 43.5 KiB 195 KiB/s 00:00 [----------------------] 100%
(1/1) checking keys in keyring [----------------------] 100%
(1/1) checking package integrity [----------------------] 100%
(1/1) loading package files [----------------------] 100%
(1/1) checking for file conflicts [----------------------] 100%
(1/1) checking available disk space [----------------------] 100%
==> root: 147
(1/1) installing debugedit [----------------------] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
(3/6) Orphaned package notification...
(4/6) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/passwd.pacnew
(5/6) Performing snapper post snapshots for the following configurations...
==> root: 148
(6/6) Syncing all file systems...
:: Sincronizando las bases de datos de los paquetes...
garuda está actualizado
core 130.6 KiB 713 KiB/s 00:00 [----------------------] 100%
extra 8.4 MiB 4.69 MiB/s 00:02 [----------------------] 100%
multilib 140.2 KiB 472 KiB/s 00:00 [----------------------] 100%
chaotic-aur 2.5 MiB 1854 KiB/s 00:01 [----------------------] 100%
descargando garuda...
descargando core...
descargando extra...
descargando multilib...
descargando chaotic-aur...
error: no se pudo obtener el archivo «chaotic-aur.db» desde cdn-mirror.chaotic.cx: The requested URL returned error: 404
error: no se pudo obtener el archivo «chaotic-aur.db» desde geo-mirror.chaotic.cx: The requested URL returned error: 404
spawn pacman -Su
warning: insufficient columns available for table display
Packages (17) bzip2-1.0.8-6 ca-certificates-mozilla-3.99-1 ding-libs-0.6.2-2
harfbuzz-8.3.1-1 harfbuzz-icu-8.3.1-1 lib32-harfbuzz-8.3.1-1
libmpd-11.8.17-6 libpipeline-1.5.7-2 libverto-0.3.2-5
nss-3.99-1 python-dateutil-2.9.0-3 rpcbind-1.2.6-4
ttf-dejavu-2.37+18+g9b5d1b2f-7 xcur2png-0.7.1-8
xorg-server-21.1.11-2 xorg-server-common-21.1.11-2
xorg-server-xephyr-21.1.11-2
Total Download Size: 9.42 MiB
Total Installed Size: 30.14 MiB
Net Upgrade Size: -0.13 MiB
xorg-server-21.1... 1455.2 KiB 1781 KiB/s 00:01 [----------------------] 100%
xorg-server-xeph... 926.9 KiB 1100 KiB/s 00:01 [----------------------] 100%
harfbuzz-8.3.1-1... 1016.3 KiB 1196 KiB/s 00:01 [----------------------] 100%
nss-3.99-1-x86_64 1641.0 KiB 1327 KiB/s 00:01 [----------------------] 100%
ttf-dejavu-2.37+... 2.6 MiB 1957 KiB/s 00:01 [----------------------] 100%
python-dateutil-... 305.5 KiB 546 KiB/s 00:01 [----------------------] 100%
ca-certificates-... 374.2 KiB 637 KiB/s 00:01 [----------------------] 100%
ding-libs-0.6.2-... 124.8 KiB 624 KiB/s 00:00 [----------------------] 100%
bzip2-1.0.8-6-x86_64 58.4 KiB 621 KiB/s 00:00 [----------------------] 100%
libmpd-11.8.17-6... 55.1 KiB 725 KiB/s 00:00 [----------------------] 100%
rpcbind-1.2.6-4-... 36.7 KiB 408 KiB/s 00:00 [----------------------] 100%
lib32-harfbuzz-8... 876.7 KiB 1092 KiB/s 00:01 [----------------------] 100%
libpipeline-1.5.... 33.6 KiB 420 KiB/s 00:00 [----------------------] 100%
xorg-server-comm... 27.6 KiB 587 KiB/s 00:00 [----------------------] 100%
libverto-0.3.2-5... 18.3 KiB 538 KiB/s 00:00 [----------------------] 100%
xcur2png-0.7.1-8... 10.3 KiB 219 KiB/s 00:00 [----------------------] 100%
harfbuzz-icu-8.3... 7.8 KiB 105 KiB/s 00:00 [----------------------] 100%
Total (17/17) 9.4 MiB 5.24 MiB/s 00:02 [----------------------] 100%
(17/17) checking keys in keyring [----------------------] 100%
(17/17) checking package integrity [----------------------] 100%
(17/17) loading package files [----------------------] 100%
(17/17) checking for file conflicts [----------------------] 100%
(17/17) checking available disk space [----------------------] 100%
==> root: 149
( 1/17) upgrading bzip2 [----------------------] 100%
( 2/17) upgrading libverto [----------------------] 100%
( 3/17) upgrading ca-certificates-mozilla [----------------------] 100%
( 4/17) upgrading ding-libs [----------------------] 100%
( 5/17) upgrading harfbuzz [----------------------] 100%
( 6/17) upgrading harfbuzz-icu [----------------------] 100%
( 7/17) upgrading lib32-harfbuzz [----------------------] 100%
( 8/17) upgrading libmpd [----------------------] 100%
( 9/17) upgrading libpipeline [----------------------] 100%
(10/17) upgrading nss [----------------------] 100%
(11/17) upgrading python-dateutil [----------------------] 100%
(12/17) upgrading rpcbind [----------------------] 100%
(13/17) upgrading ttf-dejavu [----------------------] 100%
(14/17) upgrading xcur2png [----------------------] 100%
(15/17) upgrading xorg-server-common [----------------------] 100%
(16/17) upgrading xorg-server [----------------------] 100%
(17/17) upgrading xorg-server-xephyr [----------------------] 100%
( 1/12) Creating system user accounts...
( 2/12) Reloading system manager configuration...
( 3/12) Creating temporary files...
( 4/12) Arming ConditionNeedsUpdate...
( 5/12) Rebuilding certificate stores...
( 6/12) Foreign/AUR package notification
( 7/12) Orphaned package notification...
( 8/12) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/passwd.pacnew
( 9/12) Updating fontconfig cache...
(10/12) Updating 32-bit fontconfig cache...
(11/12) Performing snapper post snapshots for the following configurations...
==> root: 150
(12/12) Syncing all file systems...
--> Updating AUR packages with paru..
:: Buscando actualizaciones de desarrollo...
:: Resolviendo dependencias...
:: Calculando conflictos...
:: Calculando conflictos internos...
Aur (1) Versión Antigua Versión Nueva Solo Construir
:: ¿Editar ahora? [S/n]: s
:: Descargando PKGBUILDs...
PKGBUILDs actualizados
pkgver=24.1.1.940
pkgrel=2
#epoch=1
Yandex Browser is a browser that combines a minimal design with sophisticated technology to make the web faster, safer, and easier."
arch=("x86_64")
depends=( "binutils" "ttf-liberation" "jq" "alsa-lib" "at-spi2-atk" "libcups" "curl" "dbus" "libdrm" "gdbm" "gtk4" "nspr" "nss" "pango"
"wayland" "libxcomposite" "libxdamage" "libxkbcommon" "libxkbfile" "libxrandr" "squashfs-tools" "wget" "xdg-utils" "harfbuzz-icu")
optdepends=(
"speech-dispatcher"
"vulkan-driver"
"vulkan-icd-loader"
"ttf-font"
"gstreamer-meta"
"cryptopro-csp-k1"
source=("${pkgname}-${_pkgver}.deb::https://repo.yandex.ru/yandex-browser/deb/pool/main/y/yandex-${_pkgname}/yandex-${_pkgname}_${_pkgver}_amd64.deb")
sha256sums=("1591e809179da471d5c226d25edb360e771437cdcf67d52554e4973e380068db")
install=yandex-browser.install
prepare() {
tar -xf data.tar.xz
package() {
cp -dr --no-preserve=ownership opt usr "${pkgdir}"/
# The stable version uses the "browser" folder in /opt/yandex. ${_pkgname} cannot be used in this section for the stable branch
# install -D -m0644 "${pkgdir}"/opt/yandex/browser/product_logo_128.png "${pkgdir}"/usr/share/pixmaps/${pkgname}.png
chmod 4755 "${pkgdir}"/opt/yandex/browser/yandex_browser-sandbox
/home/alnone/.cache/paru/clone/yandex-browser/yandex-browser.install
post_install() {
set -e
DEFAULTS_FILE="/etc/default/yandex-browser"
# Add icons to the system icons
XDG_ICON_RESOURCE="`command -v xdg-icon-resource 2> /dev/null || true`"
if [ ! -x "$XDG_ICON_RESOURCE" ]; then
echo "Error: Could not find xdg-icon-resource" >&2
exit 1
fi
for icon in product_logo_256.png product_logo_24.png product_logo_32.png product_logo_128.png product_logo_512.png product_logo_64.png product_logo_16.png product_logo_48.png ; do
size="$(echo ${icon} | sed 's/[^0-9]//g')"
"$XDG_ICON_RESOURCE" install --size "${size}" "/opt/yandex/browser/${icon}" \
"yandex-browser"
done
# Update cache of .desktop file MIME types. Non-fatal since it's just a cache.
update-desktop-database > /dev/null 2>&1 || true
altlinux_fetch_ffmpeg() {
local current_dir=$PWD
local temp_dir=$(mktemp -d --tmpdir)
cd $temp_dir
# TODO(palar): use more versatile method then download with direct link
wget https://mirror.yandex.ru/altlinux/p10/branch/x86_64/RPMS.classic/ffmpeg-plugin-browser-100-alt3.x86_64.rpm
rpm2cpio *.rpm | cpio -i --make-directories --no-absolute-filenames *libffmpeg.so
find . -name *.so -exec mv {} /opt/yandex/browser/ \;
cd $current_dir
rm -fr $temp_dir
getOsName() {
if [ -f "/etc/os-release" ]
then
cat "/etc/os-release" | grep "^ID=" | sed "s/ID=//1"
fi
codecInstallationRequired() {
current_lunux_distro=$( getOsName ) ;
if [ "$current_lunux_distro" = "ubuntu" ]; then
echo "no"
else
echo "yes"
fi
codecs_required=$( codecInstallationRequired )
if [ "$codecs_required" = "yes" ]; then
# Do not break installation anyway
/opt/yandex/browser/update_codecs /opt/yandex/browser || true
fi
# This function uses sed to insert the contents of one file into another file,
# after the first line matching a given regular expression. If there is no
# matching line, then the file is unchanged.
insert_after_first_match() {
# $1: file to update
# $2: regular expression
# $3: file to insert
sed -i -e "1,/$2/ {
/$2/ r $3
}" "$1"
# If /usr/share/gnome-control-center/default-apps/gnome-default-applications.xml
# exists, it may need to be updated to add ourselves to the default applications
# list. If we find the file and it does not seem to contain our patch already
# (the patch is safe to leave even after uninstall), update it.
GNOME_DFL_APPS=/usr/share/gnome-control-center/default-apps/gnome-default-applications.xml
if [ -f "$GNOME_DFL_APPS" ]; then
# Conditionally insert the contents of the file "default-app-block" after the
# first "<web-browsers>" line we find in gnome-default-applications.xml
fgrep -q "Yandex Browser" "$GNOME_DFL_APPS" || insert_after_first_match \
"$GNOME_DFL_APPS" \
"^[ ]*<web-browsers>[ ]*$" \
"/opt/yandex/browser/default-app-block"
fi
# This function performs the setup for the chrome management service process.
# It creates a new chromemgmt group, creates the signing key file, and updates
# permissions for both the signing key file and the binary.
chrome_management_service_setup() {
if [ ! -f "$DEFAULTS_FILE" ]; then
return
fi
if ! grep -q "install_device_trust_key_management_command=true" \
"$DEFAULTS_FILE"; then
return
fi
getent group chromemgmt > /dev/null || groupadd chromemgmt
chgrp chromemgmt "/opt/yandex/browser/chrome-management-service"
chmod 2755 "/opt/yandex/browser/chrome-management-service"
mkdir -p "/etc/opt/yandex/browser/policies/enrollment"
SIGNING_KEY_FILE="/etc/opt/yandex/browser/policies/enrollment/DeviceTrustSigningKey"
if [ ! -e "$SIGNING_KEY_FILE" ]; then
touch "$SIGNING_KEY_FILE"
fi
chgrp chromemgmt "$SIGNING_KEY_FILE"
chmod 664 "$SIGNING_KEY_FILE"
post_upgrade() {
post_install
pre_remove(){
set -e
# Remove icons from the system icons
exit 1
fi
"$XDG_ICON_RESOURCE" uninstall --size "${size}" "yandex-browser"
done
post_remove(){
set -e
remove_package_not_native_files() {
# /opt/yandex/browser/libffmpeg.so
local libffmpeg="/opt/yandex/browser/libffmpeg.so"
if [ -f "${libffmpeg}" ]; then
rm "${libffmpeg}"
echo "removed ${libffmpeg}"
fi
:: ¿Aceptar cambios? [S/n]: s
obteniendo info de desarrollo....
==> Creando el paquete: yandex-browser 24.1.1.940-2 (Mon 18 Mar 2024 08:10:46 AM EDT)
==> Recibiendo las fuentes...
-> Descargando yandex-browser-24.1.1.940-1.deb...
100 153M 100 153M 0 0 391k 0 0:06:42 0:06:42 --:--:-- 796k
==> Validando los archivos source con sha256sums...
yandex-browser-24.1.1.940-1.deb ... Aprobado
==> Creando el paquete: yandex-browser 24.1.1.940-2 (Mon 18 Mar 2024 08:17:32 AM EDT)
==> Comprobando dependencias mientras se ejecuta...
==> Comprobando dependencias mientras se compila...
-> yandex-browser-24.1.1.940-1.deb ha sido encontrado
==> Eliminando el directorio $srcdir/...
==> Extrayendo las fuentes...
-> Extrayendo yandex-browser-24.1.1.940-1.deb con bsdtar
==> Iniciando prepare()...
==> Las fuentes están listas.
yandex-browser-24.1.1.940-2: leyendo lista pkg...
==> Creando el paquete: yandex-browser 24.1.1.940-2 (Mon 18 Mar 2024 08:17:42 AM EDT)
==> ADVERTENCIA: Usando el árbol existente $srcdir/
==> Entrando en entorno fakeroot...
==> Iniciando package()...
==> Depurando la instalación...
-> Quitando los archivos libtool...
-> Purgando los archivos innecesarios...
-> Quitando los archivos de las bibliotecas estáticas...
-> Despojando los símbolos innecesarios de los binarios y de las bibliotecas...
objcopy: ./opt/yandex/browser/chrome-management-service: debuglink section already exists
objcopy: ./opt/yandex/browser/chrome_crashpad_handler: debuglink section already exists
objcopy: ./opt/yandex/browser/find_ffmpeg: debuglink section already exists
objcopy: ./opt/yandex/browser/libEGL.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libGLESv2.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libabt-bindings.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libqt5_shim.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libqt6_shim.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libvk_swiftshader.so: debuglink section already exists
objcopy: ./opt/yandex/browser/libvulkan.so.1: debuglink section already exists
objcopy: ./opt/yandex/browser/update_codecs: debuglink section already exists
objcopy: ./opt/yandex/browser/user_setup: debuglink section already exists
objcopy: ./opt/yandex/browser/yandex_browser: debuglink section already exists
objcopy: ./opt/yandex/browser/yandex_browser-sandbox: debuglink section already exists
-> Comprimiendo las páginas del manual y de información...
==> Buscando problemas de empaquetado...
==> Creando el paquete «yandex-browser»...
-> Generando el archivo .PKGINFO...
-> Generando el archivo .BUILDINFO...
-> Añadiendo el archivo install...
-> Generando el archivo .MTREE...
-> Comprimiendo el paquete...
==> Creando el paquete «yandex-browser-debug»...
==> Abandonando el entorno fakeroot.
==> Compilación terminada: yandex-browser 24.1.1.940-2 (Mon 18 Mar 2024 08:20:03 AM EDT)
==> Limpiando...
[sudo] contraseña para alnone:
cargando los paquetes...
resolviendo dependencias...
buscando conflictos entre paquetes...
Paquete (1) Versión antigua Versión nueva Diferencia neta
yandex-browser 24.1.1.940-1 24.1.1.940-2 0.00 MiB
Tamaño total de la instalación: 427.74 MiB
Tamaño neto tras actualizar: 0.00 MiB
:: ¿Continuar con la instalación? [S/n]
comprobando el depósito de claves...
verificando la integridad de los paquetes...
cargando los archivos de los paquetes...
comprobando conflictos entre archivos...
comprobando el espacio disponible en el disco...
:: Ejecutando los «hooks» de preinstalación...
==> root: 151
:: Procesando los cambios de los paquetes...
actualizando yandex-browser...
Parallel unsquashfs: Using 8 processors
1 inodes (25 blocks) to write
created 1 file
created 4 directories
created 0 symlinks
created 0 devices
created 0 fifos
created 0 sockets
created 0 hardlinks
:: Ejecutando los «hooks» de posinstalación...
.pac* files found:
/etc/passwd.pacnew
==> root: 152
System updated! 🐧
╰─λ
It seems this issue is resolved now, however just to clarify for future readers: installing debugedit is not necessary, and is in fact most likely not what most users will want.
The cause of this issue is a change was made upstream which has enabled debugging in /etc/makepkg.conf by default. I guess these will be some relevant threads if anyone is curious about this:
See archlinux/rfcs!17,
It seems the discussion is ongoing; I’m not sure if it will stay like this or not.
To get the behavior back to “normal”, the debugging option must be disabled. To do this, open /etc/makepkg.conf in an editor, for example Micro:
sudo micro /etc/makepkg.conf
Navigate down to the line that starts with OPTIONS= and put an exclamation mark in front of debug so it looks like this: “!debug” The whole line will be something like this:
OPTIONS=( ... blah blah blah blah ... !debug ...)
system
Closed
1 April 2024 20:39
10
