Hi I have been expiriancing a lot of problems regarding some of the libraries and I cannot understand what is happening:
Problem 1 EMACS
So when I try to run emacs after installing it using pacman I get the error
emacs: error while loading shared libraries: libicui18n.so.68: cannot open shared object file: No such file or directory
IDK whats the problem with that
Problem 2 R
I am using R markdown as a replacement for LaTeX but when I run sudo R I get
/usr/lib64/R/bin/exec/R: error while loading shared libraries: libicuuc.so.68: cannot open shared object file: No such file or directory
WHAT ARE THESE PROBLEMS AND WHAT CAN BE DONE
Also I do have many problems regarding mirrors for pacman as I have to see large ammounts of warning failed receiving ...
Can someone help
petsam
24 December 2020 12:08
3
It looks like you have a partial update.
Re-create your mirrorlist with Garuda utility, or reflector and do a proper update.
Check about icu package
bash -c 'grep icu /var/log/pacman.log'
tbg
24 December 2020 12:11
4
Don’t care, for your tone.
Unless you just started using the internet yesterday, you should know writing in all uppercase is rude and will get you little assistance.
Sorry I did not in any way want to be rude I just wanted the last statement to standout from the rest of the text but I am sorry if it did hurt somebody
I did use the arch mirrorlist to change the mirrors as for the other one this is my output
[2020-12-22T16:17:56+0530] [ALPM-SCRIPTLET] harfbuzz-icu 2.7.2-1 [2020-12-22T16:17:56+0530] [ALPM-SCRIPTLET] icu 67.1-1 [2020-12-22T16:17:56+0530] [ALPM-SCRIPTLET] lib32-icu 67.1-1 [2020-12-22T16:20:17+0530] [ALPM-SCRIPTLET] harfbuzz-icu 2.7.2-1 [2020-12-22T16:20:17+0530] [ALPM-SCRIPTLET] icu 67.1-1 [2020-12-22T16:20:17+0530] [ALPM-SCRIPTLET] lib32-icu 67.1-1 [2020-12-22T16:22:07+0530] [ALPM-SCRIPTLET] harfbuzz-icu 2.7.2-1 [2020-12-22T16:22:07+0530] [ALPM-SCRIPTLET] icu 67.1-1 [2020-12-22T16:22:07+0530] [ALPM-SCRIPTLET] lib32-icu 67.1-1 [2020-12-24T17:08:32+0530] [PACMAN] Running 'pacman -S icu'
petsam
24 December 2020 12:31
7
I don’t know what you mean with “arch mirrorlist”.
Anyway, you have to update your system packages. It seems some packages were not upgraded.
Run this terminal command, until there are no error messages on installations.
sudo pacman -Syyu
You have a “partial upgrade” state, your package versions are not aligned.
Refresh your mirror list and make sure your packages are fully up-to-date.
hi -
for some reason, cannot update my system due to conflicts - it appears to be broken...
any thoughts?
❯ time yay -Syu  99%   702 Mbps  ─╯
[sudo] password for XXXX
core is up to date
extra is up to date
community 5.3 MiB 15.4 MiB/s 00:00 [----------------------------------] 100%
multilib is up to date
chaotic-aur 370.6 KiB 7.24 MiB/s 00:00 [----------------------------------] 100%
warning: libldac: local (2.0.2.3-3) is newer than extra (2.0.2.3-1)
resolving dependencies...
Packages (48) autoconf-2.70-1 bbswitch-dkms-0.8-373 chaotic-keyring-20201229-1 darktable-2:3.4.0-2
dxvk-mingw-git-1.7.3.r10.gea13a686-1 firefox-ublock-origin-1.32.4-1
garuda-common-settings-r88.9fed725-1 garuda-gamer-git-r14.3d7e697-1
garuda-wallpapers-r43.3b3cd86-1 garuda-wallpapers-extra-r4.ed392ef-1
garuda-welcome-git-r86.882bf75-1 garuda-zsh-config-r23.41e56eb-1 git-2.30.0-1
gmp-6.2.1-1 grub-btrfs-4.7.2-1 harfbuzz-2.7.4-1 harfbuzz-icu-2.7.4-1
intel-gmmlib-20.4.1-1 intel-media-driver-20.4.5-1 iproute2-5.10.0-2 joplin-1.5.14-1
lib32-harfbuzz-2.7.4-1 lib32-mpg123-1.26.4-1 libarchive-3.5.1-1 libavif-0.8.4-1
libmicrohttpd-0.9.72-1 libmpc-1.2.1-1 libproxy-0.4.17-1 linux-zen-5.10.3.zen1-1
linux-zen-headers-5.10.3.zen1-1 mhwd-db-garuda-git-r44.0fee18d-1 oath-toolkit-2.6.5-1
openexr-2.5.3-6 openjpeg2-2.4.0-1 perl-libwww-6.51-1 python-pip-20.2.4-1
python-reportlab-3.5.57-1 python-resolvelib-0.5.4-1 python-setuptools-1:51.1.1-1
python-urllib3-1.26.1-1 rsync-3.2.3-3 sof-firmware-1.6.1-1 terminus-font-4.49.1-1
tzdata-2020f-1 udftools-2.2-2 whitesur-gtk-theme-git-2020.12.27.r0.g1c26ca6-1
xf86-video-intel-1:2.99.917+914+ga511f22c-1 youtube-dl-2020.12.31-1
Total Installed Size: 794.22 MiB
Net Upgrade Size: -538.97 MiB
(48/48) checking keys in keyring [----------------------------------] 100%
(48/48) checking package integrity [----------------------------------] 100%
(48/48) loading package files [----------------------------------] 100%
(48/48) checking for file conflicts [----------------------------------] 100%
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/cli-32.exe exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/cli-64.exe exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/cli.exe exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/command/launcher manifest.xml exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/gui-32.exe exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/gui-64.exe exists in filesystem
python-setuptools: /usr/lib/python3.9/site-packages/setuptools/gui.exe exists in filesystem
python-urllib3: /usr/lib/python3.9/site-packages/urllib3/util/__pycache__/proxy.cpython-39.pyc exists in filesystem
python-urllib3: /usr/lib/python3.9/site-packages/urllib3/util/__pycache__/ssltransport.cpython-39.pyc exists in filesystem
python-urllib3: /usr/lib/python3.9/site-packages/urllib3/util/proxy.py exists in filesystem
python-urllib3: /usr/lib/python3.9/site-packages/urllib3/util/ssltransport.py exists in filesystem
error installing repo packages
yay -Syu 1.39s user 0.57s system 15% cpu 12.875 total
SGS
1 January 2021 14:15
10
use
sudo pacman -Syu --overwrite "*"
or search in
man yay
that does something like this.
WTF
Did you install something via pip (namely setuptools & urllib3)?
SGS
1 January 2021 15:19
12
OMG I read only the last "ssltransport.cpython-39.pyc exists in filesystem"
I am too old for this sh!t
system
Closed
11 July 2023 13:59
13
