Problem to install CLion IDE
Hello Garuda users.
I have a problem when i install CLion IDE ?
after i install it from this command
yay -S clion
when i open it this problem face me
No JRE found. Please make sure $CLION_JDK, $JDK_HOME, or $JAVA_HOME point to valid JRE installation.
can someone help me ?
As it says install JRE in your system. Follow the wiki below to install JRE set paths as required.
https://wiki.archlinux.org/title/java
You can also take a look at this in case wiki doesn't make a lot of sense to you,
Also always provide your garuda-inxi even if you feel that it's not necessary, it's the template.
thx so much Bro , it works successfully
I'm Bro, he's @NaN :frowning:
