Hallo. Wenn ich ein Systemupdate starte bekomme ich folgende Fehlermeldung…Kann mir jemand helfen?
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.12.13-1-cachyos-lts
Module nvidia/570.86.16 is not installed for kernel 6.12.13-1-cachyos-lts (x86_64). Skipping...
Module nvidia/570.86.16 is not built for kernel 6.12.13-1-cachyos-lts (x86_64). Skipping...
Error! Your kernel headers for kernel 6.12.13-1-cachyos-lts cannot be found at /usr/lib/modules/6.12.13-1-cachyos-lts/build or /usr/lib/modules/6.12.13-1-cachyos-lts/source.
Please install the linux-headers-6.12.13-1-cachyos-lts package or use the --kernelsourcedir option to tell DKMS where it's located.
---> Failed to build NVIDIA DKMS module for kernel 6.12.13-1-cachyos-lts
System updated! 🐧
Hier ist meine inxi…
[🔍] × garuda-inxi
Kernel: 6.12.13-1-cachyos-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-lts
root=UUID=10157110-2cd6-485c-860f-a47c5735c0f1 rw rootflags=subvol=@
quiet resume=UUID=b6306d6a-f89f-48e6-a98a-91af0fb78502 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: ASUSTeK product: ROG Strix G713QR_G713QR v: 1.0
Mobo: ASUSTeK model: G713QR v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QR.327
date: 03/29/2022
ID-1: BAT0 charge: 69.7 Wh (87.0%) condition: 80.1/90.0 Wh (89.0%)
volts: 16.5 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
microcode: 0xA500011
Speed (MHz): avg: 1089 min/max: 400/4890 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1089 2: 1089 3: 1089
4: 1089 5: 1089 6: 1089 7: 1089 8: 1089 9: 1089 10: 1089 11: 1089 12: 1089
13: 1089 14: 1089 15: 1089 16: 1089 bogomips: 105400
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 39.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x1440
display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: AOC Q24G2 serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 124 gamma: 1.2
size: 526x296mm (20.71x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 pos: right model: BOE Display 0x0a08 built: 2021 res:
mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 171 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
renoir LLVM 19.1.7 DRM 3.59 6.12.13-1-cachyos-lts) device-ID: 1002:1638
API: Vulkan v: 1.4.303 layers: 12 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
vendor: ASUSTeK driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
API: ALSA v: k6.12.13-1-cachyos-lts status: kernel-api with: aoss
Device-3: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u2 state: down mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Local Storage: total: 1.4 TiB used: 416.1 GiB (29.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HAJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 4L1QEXA7 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
used: 415.81 GiB (44.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 297.9 MiB (99.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-4: /var/log raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
ID-2: swap-2 type: zram size: 15.04 GiB used: 278.2 MiB (1.8%)
System Temperatures: cpu: 48.9 C mobo: 28.0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.04 GiB used: 6.76 GiB (44.9%)
Processes: 387 Power: uptime: 1h 7m states: freeze,mem,disk
suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,
Packages: 1732 pm: pacman pkgs: 1725 libs: 529 tools: octopi,paru
pm: flatpak pkgs: 7 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date:     2024-07-14
Last full system update: 2025-02-21
Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
