Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b78f0ace-4b76-4ecb-911e-371d2a924668 rw rootflags=subvol=@
resume=UUID=fad1c9fd-e4b0-4830-9857-17676d6daf30 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Acer product: Swift SFX14-42G v: V1.00
Mobo: BC model: Orion_BCU v: V1.00 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.00
date: 01/27/2022
ID-1: BAT1 charge: 35.1 Wh (100.0%) condition: 35.1/38.1 Wh (92.0%)
volts: 16.9 min: 15.4 model: COMPAL type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 629 high: 2469 min/max: 400/4546 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 2469 12: 1996
13: 400 14: 400 15: 400 16: 400 bogomips: 63880
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-2: AMD Barcelo vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 45.0 C
Device-3: Quanta Acer FHD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:4036
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1408 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.10.9-zen1-2-zen) device-ID: 1002:15e7
memory: 500 MiB unified: no
API: Vulkan v: 1.3.295 layers: 15 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.2-arch1.1
device-ID: 1002:15e7 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Ti Laptop GPU driver: nvidia v: 560.35.03
device-ID: 10de:25a0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04ca:3802
Local Storage: total: 476.94 GiB used: 277.58 GiB (58.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41020C20 temp: 43.9 C
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 277.58 GiB (60.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.98 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.2 C mobo: 40.0 C gpu: amdgpu temp: 45.0 C
Memory: total: 16 GiB note: est. available: 14.98 GiB used: 4.69 GiB (31.3%)
Processes: 367 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
image: 5.92 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2176 pm: pacman pkgs: 2170 libs: 590 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13
Shell: garuda-inxi default: Bash v: 5.2.32 running-in: konsole
inxi: 3.3.35
System install date: 2024-07-28
Last full system update: 2024-09-12
I can’t seem to have much more than one application run at a time. Example had to close Konsule to open LibreWolf. Have to close LibreWolf to launch Thunderbird. If I have any decent sized program running, everything else including Dolphin will give and error and not launch.
I’m not sure exactly what started this problem. I had restored to a previous snapshot yesterday when it started but that didn’t work.
I found this thread Cant start any app - #44 by petsam in the forum and tried changing RuntimeDirectorySize=8G from the default 10% but the problem still persists after restart
