hello people, i have a problem installin garuda bspwm version, it show this message
mount: /run/miso/sfs/rootfs: wrong fs type, bad option, bad superblock on /dev/loop3, missing codepage or helper program, or other error.
error; failed to mount '/dev/loop3´
falling back to interactive prompt
you can try to fix the problem manually, log out when you are finished
sh: can´t acces tty; job control turned off
