Installed Charles. I'm trying to install a certificate using the program itself. Errors appear in the console
- (gcr-viewer:50585): WARNING **: 14:31:09.231: Unable to connect to dbus: Произошла ошибка при создании проц
есса командной строки «dbus-launch --autolaunch=7b00a2ef1d814794893b2162f97bd5d5 --binary-syntax --close-stder
r»: Дочерний процесс завершился с кодом 1
(gcr-viewer:50585): GLib-GIO-CRITICAL **: 14:31:09.268: g_dbus_connection_register_object: assertion 'G_IS_DBU
S_CONNECTION (connection)' failed
(gcr-viewer:50585): GLib-GIO-CRITICAL **: 14:31:09.268: g_dbus_connection_get_unique_name: assertion 'G_IS_DBU
(gcr-viewer:50585): Gcr-WARNING **: 14:31:13.536: couldn't load ui builder file: Ресурс из «/org/gnome/gcr/ui/
gcr-pkcs11-import-dialog.ui» не существует
(gcr-viewer:50585): Gtk-CRITICAL **: 14:31:13.536: gtk_entry_set_text: assertion 'GTK_IS_ENTRY (entry)' failed
(gcr-viewer:50585): GLib-GIO-CRITICAL **: 14:31:13.543: g_dbus_connection_register_object: assertion 'G_IS_DBU
(gcr-viewer:50585): GLib-GIO-CRITICAL **: 14:31:13.543: g_dbus_connection_get_unique_name: assertion 'G_IS_DBU
Installed the certificate manually. By adding to the /etc/ca-certificates/trust-source/anchors/ folder
and team update
trust extract-compat
but Charless still displays the requests in encrypted form.
I ask for help
