Garuda Inxi:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e7454ee6-b5e4-487a-b0dc-d8af91efa048 rw rootflags=subvol=@
quiet loglevel=3 amdgpu.ppfeaturemask=0xffffffff ibt=off
v: 5.115.0 wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Garuda
Type: Desktop Mobo: ASRock model: B650M PG Riptide
Megatrends LLC. v: 1.11 date: 10/21/2022
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1912 high: 4674 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3362 2: 3930 3: 400
4: 400 5: 400 6: 400 7: 3475 8: 4674 9: 400 10: 400 11: 3479 12: 4631
13: 3446 14: 400 15: 400 16: 400 bogomips: 143720
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 3840x2160 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 16.0.6 DRM 3.57 6.7.4-zen1-1-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 23.3.5-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
Device-4: Elgato Systems GmbH Wave:1 driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0fd9:006e
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:7 chip-ID: 0b05:190e
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.88 TiB used: 1.57 TiB (83.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T700SSD5
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5101 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: USB3.0 CRW -SD
size: 59.48 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.53 TiB (84.1%)
used: 1.53 TiB (84.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.05 GiB used: 5.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 38.0 C
Memory: total: 32 GiB note: est. available: 31.06 GiB used: 9.78 GiB (31.5%)
Processes: 386 Power: uptime: 9h 55m states: freeze,mem,disk
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1849 libs: 493 tools: octopi,paru,yay
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-10-29
Last full system update: 2024-02-19 ↻
I would like to view image thumbnails of .cr3 Raw photos taken with my Canon camera in Dolphin, so I don’t have to open Darktable for every single one. Darktable works fine to view them but I want the ability to cull quicker.
Steps I’ve taken to resolve:
google, which pointed me to out of date LibRaw as a possible solution. I checked and I am running the latest version of LibRaw. LibRaw also supports my camera model.
The same page pointed me to out of date exiv as another reason why Dolphin is unable to generate .cr3 thumbnails. Exiv is also up to date.
Is there anything else I can do to fix this?
