Printer HPLIP 5012 communication error HP Laser Jet 1018
Worth noting that garuda won’t load with printer plugged in, and upon plugging in dmesg returns:
[  130.035132] usb 1-4: new high-speed USB device number 7 using xhci_hcd
[  135.547744] usb 1-4: device descriptor read/64, error -110
hmm.. over cups webinterface or plasma settings ?
Also konsole then system-config-printer
Konsole sudo dmesg
I think the issue is something about pc not discovering the printer
And quick lookup over device descriptor read/64, error -110 returns that it’s an error that can sometimes be fixed by disarming electricity in the system, which i did in the morning which made my printer work exactly once. I guess i should get a new cable?.. Because the specifics of why it happens are vague.
Here’s uncontinuous dmesg logs on what seems to be related from another successful attempt i did just now, the printer shortly disconnected though
[    2.452230] usb 1-4: new high-speed USB device number 4 using xhci_hcd
[    2.659312] usb 1-4: New USB device found, idVendor=03f0, idProduct=4117, bcdDevice= 1.00
[    2.659317] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.659319] usb 1-4: Product: HP LaserJet 1018
[    2.659322] usb 1-4: Manufacturer: Hewlett-Packard
[    2.659324] usb 1-4: SerialNumber: KP0ARZJ
[   74.615627] usblp 1-4:1.0: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x03F0 pid 0x4117
[   74.615670] usbcore: registered new interface driver usblp
<-- i disconnected it here -->
[  241.717352] usb 1-4: USB disconnect, device number 4
[  241.717507] usblp0: removed
[  244.849832] usb 1-4: new high-speed USB device number 7 using xhci_hcd
[  250.103837] usb 1-4: device descriptor read/64, error -110
[  265.975114] usb 1-4: device descriptor read/64, error -110
[  266.257355] usb 1-4: new high-speed USB device number 8 using xhci_hcd
[  271.606146] usb 1-4: device descriptor read/64, error -110
[  287.478328] usb 1-4: device descriptor read/64, error -110
[  287.587209] usb usb1-port4: attempt power cycle
[  288.026988] usb 1-4: new high-speed USB device number 9 using xhci_hcd
[  293.448199] usb 1-4: device descriptor read/8, error -110
[  308.807186] usb 1-4: device descriptor read/8, error -110
[  309.085838] usb 1-4: new high-speed USB device number 10 using xhci_hcd
[  314.438910] usb 1-4: device descriptor read/8, error -110
[  329.800050] usb 1-4: device descriptor read/8, error -110
[  329.906536] usb usb1-port4: unable to enumerate USB device
I type this in my first post…
but we had also a update for cups (10 days ago)
Your BIOS is quite old. I would highly recommend to update to the latest version
https://www.msi.com/Motherboard/MPG-B550-GAMING-PLUS/support#bios
Sometimes updates don’t play nice with very outdated BIOS versions. Also I’ve noticed one version you are missing out on mentions “Improved USB device compatibility” , so it might have a chance to fix some of your issues, mainly this one as it can be a BIOS related issue:
(Note: You are missing out on very important security fixes and it is very much worth updating the BIOS anyways.)
Correct.
The printer is not recognized as a USB device at hardware level. Either there is a problem with the corresponding USB port`s on the computer side or on the printer side, or the USB cable or the printer is defective.
And you should also consider this suggestion:
Been a few days since last post, update:
I did a wrong format of BIOS thing (was supposed to put them into root folder) and learned MSI coded BIOS in a way launching flash mode and choosing nothing may put it into mode that can only be reset via battery removal
Got a new cable, fixed BIOS, flashed BIOS, learned that the windows OS on my pc has no troubles with locating printer over old cable. Trying garuda with updated bios & changed cable however still gives me an issue of hp device manager saying it can’t locate hp device and dmesg claiming something went wrong with connection. I may have done pacman -Syu at some point though, which may be the reason the messages in dmesg changed
dmesg (new cable, new BIOS):
[ 3912.353067] usb usb1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3913.305076] usb usb1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3913.307504] usb usb1-port3: attempt power cycle
[ 3914.321104] usb usb1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3915.273092] usb usb1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3915.275513] usb usb1-port3: unable to enumerate USB device
here’s the updated INXI:
Kernel: 6.14.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=685e13de-1daa-43f1-a4c5-8b4503aa7954 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <filter> uuid: a49d6505-6346-bc1a-a838-d8bbc139f029 BIOS: American
Megatrends LLC. v: 1.J0 date: 03/19/2025
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 1723 min/max: 550/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1723 2: 1723 3: 1723 4: 1723
5: 1723 6: 1723 7: 1723 8: 1723 9: 1723 10: 1723 11: 1723 12: 1723
bogomips: 86393
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 575.57.08 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: DP-1,HDMI-A-1
empty: DP-2,DP-3 bus-ID: 2b:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3200x1294 s-dpi: 96 s-size: 847x342mm (33.35x13.46")
s-diag: 913mm (35.96")
Monitor-1: DP-1 note: disabled pos: primary,bottom-l model: HP Z23i
serial: <filter> built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 96 gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23")
Monitor-2: HDMI-A-1 note: disabled pos: top-right
model: ViewSonic VA926 Series serial: <filter> built: 2007 res:
mode: 1280x1024 hz: 60 scale: 100% (1) dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.57.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.4.313 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 575.57.08 device-ID: 10de:2182
surfaces: N/A
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 2b:00.1 chip-ID: 10de:1aeb class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 5
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 1038:12aa class-ID: 0300
API: ALSA v: k6.14.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.5 status: n/a (root, process) with:
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.95 TiB used: 164.02 GiB (8.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 35.9 C
SMART: yes health: PASSED on: 23d 1h cycles: 4,168
read-units: 15,779,673 [8.07 TB] written-units: 18,867,523 [9.66 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4
family: Barefoot_2/Everest/Martini based SSDs size: 119.24 GiB block-size:
physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 1.5 scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 353d 5h cycles: 9069
ID-3: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: HFS512G39TND-N210A
family: SATA SSDs size: 476.94 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1P10 temp: 31 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 298d 17h cycles: 5661
model: WD1002FAEX-00Z3A0 family: Caviar Black size: 931.51 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1D05 temp: 41 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 5y 68d 6h cycles: 7273
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 164.02 GiB (35.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 259:2
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 259:2
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 133.2 MiB (0.8%)
System Temperatures: cpu: 42.6 C mobo: N/A
Memory: total: 16 GiB available: 15.54 GiB used: 5.75 GiB (37.0%)
Processes: 372 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: 1560 pm: pacman pkgs: 1534 libs: 428 tools: octopi,paru
pm: flatpak pkgs: 26 Compilers: gcc: 15.1.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
System install date:     2025-03-08
Last full system update: 2025-06-09
That’s not correct, use garuda-update and if you have aur packages installed use garuda-update --a. Or short upd and upd -a.
Do you have the printer connected on the case or motherboard ?
Your printer → 2.0 high speed.
Try another port and then ?
If it still doesn’t work on Linux but does on windows, then it shouldn’t be a hardware or BIOS issue.
What comes to my mind is the USB power management. Possibly the printer has a problem with USB power saving / USB auto-suspend. This is normally handled by the kernel, possibly the actual cause is a previous kernel update. Have you tried a different kernel, for example linux-lts?
Another possibility would be to disable the USB auto-suspend via udev rules - have a look at the ArchWiki, it’s there somewhere.
just tried connecting to motherboard port instead of case one, dmesg is different, hp device manager still can’t see it though:
[  325.710303] usb 1-9: new high-speed USB device number 5 using xhci_hcd
[  325.918716] usb 1-9: New USB device found, idVendor=03f0, idProduct=4117, bcdDevice= 1.00
[  325.918723] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  325.918726] usb 1-9: Product: HP LaserJet 1018
[  325.918728] usb 1-9: Manufacturer: Hewlett-Packard
[  325.918730] usb 1-9: SerialNumber: KP0ARZJ
[  329.807851] WARNING! power/level is deprecated; use power/control instead
[  335.228734] usblp 1-9:1.0: usblp0: USB Bidirectional printer dev 5 if 0 alt 0 proto 2 vid 0x03F0 pid 0x4117
[  335.228775] usbcore: registered new interface driver usblp
Thank you, will figure it out later. Where can i see good resources on kernel swapping for garuda?
Over pacseek, oktopi, garuda settings manager → kernel or rani
To look i prefer oktopi but for kernels i use garuda settings manager → kernel.
To install use sudo pacman -S package
Matisse CPU = Zen 2 (gen3)
example:
sudo packman -S linux-znver2 linux-znver2-headers
Current on your system is kernel 6.14 zen installed, for me, a little bit faulty kernel.
Over garuda-update is updated then to kernel 6.15.
Perhaps then your printer is function.
