Preferences, general seetings disapear after update. Can't change language settings. Some advice "how to"?
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Kernel: 6.2.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b2d11c2c-5b15-481c-9e8a-3f07b87b4094 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: GA-970A-D3 v: x.x
serial: <superuser required> BIOS: Award v: F13b date: 12/16/2013
Info: model: AMD FX-8300 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1610 high: 1913 min/max: 1400/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1409 2: 1681
3: 1409 4: 1871 5: 1408 6: 1409 7: 1913 8: 1781 bogomips: 61206
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Screen-1: 0 s-res: 1921x2160 s-dpi: 91 s-size: 535x602mm (21.06x23.70")
s-diag: 805mm (31.71")
Monitor-1: DVI-D-0 pos: primary,bottom-r res: 1920x1080 hz: 60 dpi: 93
Monitor-2: HDMI-0 pos: top-left res: 1920x1080 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX
1050/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
Device-2: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus-ID: 05:07.0 chip-ID: 13f6:8788
class-ID: 0401
Sound API: ALSA v: k6.2.5-zen1-1-zen running: yes
lanes: 1 port: de00 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Conwise CW6622 type: USB driver: btusb v: 0.8 bus-ID: 1-1:2
chip-ID: 0e5e:6622 class-ID: e001
address: <filter>
Local Storage: total: 948.11 GiB used: 665.34 GiB (70.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: KODAK SSD X100
type: SSD serial: <filter> rev: 61I3 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD642JJ
size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1113 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3250318AS
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: HP35 scheme: MBR
ID-4: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk
model: Cruzer Switch size: 7.26 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 43.21 GiB size: 43.21 GiB (100.00%)
used: 14.39 GiB (33.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 68.57 GiB size: 66.94 GiB (97.63%)
used: 24.53 GiB (36.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 43.21 GiB size: 43.21 GiB (100.00%)
ID-4: /var/tmp raw-size: 43.21 GiB size: 43.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.6 GiB used: 135.8 MiB (0.8%)
System Temperatures: cpu: 28.1 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 289 Uptime: 12h 26m wakeups: 0 Memory: 15.6 GiB
used: 5.05 GiB (32.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1767
libs: 441 tools: octopi,pamac,paru Shell: fish v: 3.6.0 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-11
Last full system update: 2023-03-18 ↻
Restart your PC.
This was already mentioned, the currently building package is supposed to fix it.
Edit: the package is available now, update your system and try again please.
It's ok now.
thx.
