Ppp 2.5.0-1 breaks dependency ppp=2.4.9
I was performing an update
  • mistakenly passed an keyboard Interrept during post transaction hooks (dpmod restoring the linux-zen)
  • I then intentially haulted the whole process to restart the udpate
  • I tried garuda-update , and it thrown me the following error
╭─starboy@starboy in ~ via  took 6ms
╰─λ garuda-update
[sudo] password for starboy:
garuda is up to date
core is up to date
extra                                                  8.3 MiB  3.70 MiB/s 00:02 [----------------------------------------------] 100%
multilib                                             143.0 KiB   397 KiB/s 00:00 [----------------------------------------------] 100%
chaotic-aur is up to date
blackarch is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
blackarch downloading...
resolving dependencies...
:: installing ppp (2.5.0-1) breaks dependency 'ppp=2.4.9' required by networkmanager-fortisslvpn
  • I rebooted the system, was unable to boot to linux-zen
  • booted to the system using linux-lts
  • tried garuda-update again
  • again throwed the same error
  • checked apps , apps are updated properly
    please help me fix my linux-zen
    Here is my gaurda-inxi
Kernel: 6.1.52-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f6c17212-3382-420b-9c2d-8476e08ec308 rw rootflags=subvol=@
resume=UUID=299aed37-7c21-412d-acac-bb2d885a9f4d loglevel=3 ibt=off
Type: Laptop System: Acer product: Aspire A515-51G v: V2.02
Mobo: KBL model: Charmander_KL v: V2.02 serial: <superuser required>
UEFI: Insyde v: 2.02 date: 01/03/2019
ID-1: BAT1 charge: 34.6 Wh (100.0%) condition: 34.6/48.9 Wh (70.6%)
volts: 16.6 min: 15.2 model: LG 004B384234314341 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1675 high: 1800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1800 2: 1800 3: 1800
4: 1800 5: 1800 6: 800 7: 1800 8: 1800 bogomips: 28808
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 0408:a060
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0959 built: 2020 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: Mesa Intel UHD Graphics
620 (KBL GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.1.52-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.1 chip-ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3
chip-ID: 04ca:3015 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 931.51 GiB used: 889.82 GiB (95.5%)
model: WD10SPZX-21Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 889.82 GiB (96.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 256 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 256 Uptime: 24m wakeups: 1 Memory: total: 8 GiB
available: 7.64 GiB used: 3.83 GiB (50.2%) Init: systemd v: 254
pm: pacman pkgs: 1476 libs: 385 tools: octopi,paru,yay Shell: fish v: 3.6.1
running-in: konsole inxi: 3.3.29
System install date:     2023-03-07
Last full system update: 2023-07-22
Is partially upgraded:   Yes
Thanks in Advance!
See if this works,
sudo pacman -Rdd networkmanager-fortisslvpn
garuda-update
sudo pacman -Rns $(pacman -Qtdq)
It seems networkmanager-fortisslvpn has been removed from extra repo in arch and it’s AUR versions have been marked orphaned.
Also, in case you still can’t boot using zen kernel try,
sudo dkms autoinstall
and,
sudo dracut-rebuild
I couldn’t boot into the linux-zen after these executing these commands
then I tried reinstalling the linux-zen and linux-zen-headers and it worked out for me
Thanks a lot for your kind assistance and helping me out in restoring my system’s primary kernal. Thanks a Lot! @NaN
