Powersave-tweaks invalide signature
Hi.
I want to install some powersave tweeks but this one is exit with the following error:
resolving dependencies...
Package (1)              New Version  Net Change  Download Size
garuda/powersave-tweaks  2.0.0-1        0.00 MiB       0.00 MiB
Total Download Size:   0.00 MiB
Total Installed Size:  0.00 MiB
:: Retrieving packages...
 powersave-tweaks-2.0.0-1-any                      3.6 KiB  9.97 KiB/s 00:00 [-------------------------------------------] 100%
(1/1) checking keys in keyring                                               [-------------------------------------------] 100%
(1/1) checking package integrity                                             [-------------------------------------------] 100%
error: powersave-tweaks: signature from "TNE <tne@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/powersave-tweaks-2.0.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Press enter to exit
Any idea for fix this?
garuda-inxi:
 ╰─λ garuda-inxi
  Kernel: 6.7.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=095c9f1d-4e23-42b2-aa42-36402880711e rw rootflags=subvol=@
    quiet resume=UUID=4b8a0d61-7df0-445b-9329-0c5cf2f2c346 loglevel=3 ibt=off
  Type: Laptop System: Dell product: Vostro 3580 v: N/A
  Mobo: Dell model: 0PMTCG v: A00 serial: <superuser required> UEFI: Dell
    v: 1.27.0 date: 11/16/2023
  ID-1: BAT0 charge: 29.3 Wh (100.0%) condition: 29.3/42.0 Wh (69.8%)
    volts: 12.7 min: 11.4 model: BYD DELL 1VX1H97 type: Li-ion serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    stepping: 0xC (12) microcode: 0xF8
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 625 high: 700 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 700 2: 700 3: 700 4: 400
    5: 700 6: 400 7: 700 8: 700 bogomips: 28800
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
    ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
    chip-ID: 1bcf:2b98 class-ID: 0e02
    compositor: Hyprland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 4480x1080
    display-ID: 1
  Monitor-1: HDMI-A-1 pos: right model: LG (GoldStar) ULTRAWIDE
    serial: <filter> built: 2014 res: 2560x1080 hz: 60 dpi: 112 gamma: 1.2
    scale: 1 size: 677x290mm (26.65x11.42") diag: 628mm (24.7") modes:
    max: 2560x1080 min: 720x400
  Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x38ed built: 2015
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 scale: 1
    modes: 1920x1080
  API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (WHL GT2) driver: mesa intel v: 23.3.3-arch1.1
    device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    bus-ID: 0000:00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.7.1-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:01:00.0
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:02:00.0
    chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: wguk121t state: unknown speed: N/A duplex: N/A mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0cf3:e009
    driver: intel_nvme_remap v: N/A port: 4060 bus-ID: 0000:00:17.0
    chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.36 TiB used: 12.11 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B tech: SSD serial: <filter> fw-rev: 10410106 temp: 20.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
    serial: <filter> fw-rev: 3R17 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM 024 HN-M101M
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 2AR2 scheme: MBR
  ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 10.44 GiB (17.4%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 162.16 GiB size: 162.16 GiB (100.00%)
    used: 1.66 GiB (1.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
    used: 10.44 GiB (17.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 16.01 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 63.0 C pch: 61.0 C mobo: 38.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 251 Uptime: 9m wakeups: 0 Memory: total: 8 GiB
  available: 7.63 GiB used: 3.25 GiB (42.6%) Init: systemd v: 255
  pm: pacman pkgs: 1410 libs: 411 tools: paru Shell: fish v: 3.7.0
  running-in: foot inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-21
  Last full system update: 2024-01-24
tank you.
Try
garuda-update remote fix
and then see if that helps?
No. I got the same error.
Just wait a little, and try again
I still have this error.
Maybe @TNE can help.
