Hello, I get an inconsistent issue with the kde power-profiles-daemon that lets you switch between performance, balanced, and power-saving modes. Sometimes the feature does not work and trying to move the slider in the system tray app sends an error notification saying “Failed to activate balanced mode” (or whatever mode was selected). Thing is sometimes it works when I first turn on the computer, and sometimes it will work after one or more restarts, and I don’t understand why. Any advice on how to make it work consistently is appreciated.
I checked systemctl status power-profiles-daemon and got the following output. Obviously something is not working correctly, but I’m not sure what to do to fix it.
● power-profiles-daemon.service - Power Profiles daemon
Loaded: loaded (/usr/lib/systemd/system/power-profiles-daemon.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-10-11 14:09:36 EDT; 2h 4min ago
Main PID: 653 (power-profiles-)
Tasks: 4 (limit: 38172)
Memory: 5.3M
CPU: 156ms
CGroup: /system.slice/power-profiles-daemon.service
└─653 /usr/lib/power-profiles-daemon
Oct 11 14:09:36 weds4-20hjs7dg00 systemd[1]: Started Power Profiles daemon.
Oct 11 15:53:13 weds4-20hjs7dg00 power-profiles-[653]: Failed to activate driver 'intel_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy1/energy_performance_preference': Device or resource busy
Oct 11 15:53:19 weds4-20hjs7dg00 power-profiles-[653]: Failed to activate driver 'intel_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy1/energy_performance_preference': Device or resource busy
Oct 11 16:03:07 weds4-20hjs7dg00 power-profiles-[653]: Failed to activate driver 'intel_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy1/energy_performance_preference': Device or resource busy
Oct 11 16:12:00 weds4-20hjs7dg00 power-profiles-[653]: Failed to activate driver 'intel_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy1/energy_performance_preference': Device or resource busy
My garuda-inxi is below.
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f6de50df-1b53-4507-a69d-8201ec25043a rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: LENOVO product: 20HJS7DG00 v: ThinkPad P51
Mobo: LENOVO model: 20HJS7DG00 v: SDK0Q40112 WIN
serial: <superuser required> UEFI: LENOVO v: N1UET86W (1.60 )
date: 11/30/2022
ID-1: BAT0 charge: 69.5 Wh (99.0%) condition: 70.2/90.0 Wh (78.0%)
power: 5.2 W volts: 12.9 min: 11.2 model: SMP 00NY493 type: Li-poly
serial: <filter> status: charging cycles: 967
Info: model: Intel Xeon E3-1505M v6 bits: 64 type: MT MCP arch: Kaby Lake
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3600 min/max: 800/4000 scaling: driver: intel_pstate
governor: performance cores: 1: 3600 2: 3600 3: 3600 4: 3600 5: 3600 6: 3600
7: 3600 8: 3600 bogomips: 48000
Device-1: Intel HD Graphics P630 vendor: Lenovo driver: i915 v: kernel
empty: none bus-ID: 00:02.0 chip-ID: 8086:591d class-ID: 0300
Device-2: NVIDIA GM206GLM [Quadro M2200 Mobile] vendor: Lenovo
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1436
class-ID: 0302
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 04f2:b5ab
class-ID: 0e02
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics 0x21eb built: 2016 res: 1920x1080
hz: 60 dpi: 141 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
ratio: 16:9 modes: 3840x2160
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics P630 (KBL
GT2) device-ID: 8086:591d memory: 30.46 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: integrated-gpu
name: Intel HD Graphics P630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:591d surfaces: xcb,xlib device: 1 type: discrete-gpu
name: Quadro M2200 driver: nvidia v: 535.113.01 device-ID: 10de:1436
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fba class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
Local Storage: total: 953.87 GiB used: 56.75 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: H230331a temp: 39.9 C scheme: GPT
ID-1: / raw-size: 224 GiB size: 224 GiB (100.00%) used: 56.72 GiB (25.3%)
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 224 GiB size: 224 GiB (100.00%)
used: 56.72 GiB (25.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 224 GiB size: 224 GiB (100.00%)
ID-5: /var/tmp raw-size: 224 GiB size: 224 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.19 GiB used: 5.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 92.0 C pch: 59.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 4491 fan-2: 4492
Processes: 285 Uptime: 2h 0m wakeups: 1 Memory: total: 32 GiB
available: 31.19 GiB used: 5.57 GiB (17.8%) Init: systemd v: 254
pm: pacman pkgs: 2019 libs: 574 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-09-17
Last full system update: 2023-10-11 ↻
