Possible To Install Garuda with XFS instead of BTRFS?
Just found out that only BTRFS is available. What happened to the likes Ext4. Xfs?
I would like to make a new install using XFS.
Chorus: why?
It’s Linux can I do that? if yes how to go about it?
IMHO I don’t see this as something requiring garuda-inxi, but here it.
  Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=ca46cfb3-682f-4d27-ab75-37f70793ff5a rw rootflags=subvol=@
    quiet resume=UUID=b8625a64-75a5-4b7a-9aeb-c6aef537fd04 loglevel=3
    split_lock_detect=off sysrq_always_enabled=1 ibt=off
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
  Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: X515EA.309
    date: 05/16/2022
  ID-1: BAT0 charge: 34.5 Wh (96.9%) condition: 35.6/37.1 Wh (96.0%)
    volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 34
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    microcode: 0xB6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 38707
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1,HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 322e:2103
    class-ID: 0e02
  Monitor-1: eDP-1 res: 1670x939 size: N/A modes: N/A
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 14.96 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
    Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.7-arch1.3
    device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.0.7-arch1.3 (LLVM 17.0.6) device-ID: 10005:0000
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
    v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0032
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 931.51 GiB used: 77.18 GiB (8.3%)
    fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
    used: 77.18 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
  ID-4: /var/log raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
  ID-5: /var/tmp raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2300
  Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.23 GiB (21.1%)
  Processes: 250 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1611 libs: 421 tools: octopi,paru Compilers:
    gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
    inxi: 3.3.34
  System install date:     2024-01-25
  Last full system update: 2024-05-19
If you want to use the Calamares installer, it is Btrfs or nothing. If you don’t use Btrfs, a lot of the Garuda-specific tools will not work. There is not a lot of sense building support into the installer for other file systems, only to have people complain when everything is broken because they chose ext4 or whatever.
Of course you can! :smile:
An easy way to accomplish this would be to just install Arch Linux with whatever filesystem and partitioning setup you want, then add the Garuda repo afterward and pull in the rest of the packages you need. We have some folks that do this in order to use Garuda Linux on ext4 as well.
That’s an option.
Makes sense. Will think about that and make a decision.
Thanks for clarifying things for me.
You can edit /etc/calamares/modules/partitions.conf before starting calamares.
Uncomment the availableFileSystemTypes line and add xfs:
availableFileSystemTypes: ["btrfs","xfs"]
Save the file and start calamares. The xfs filesystem can now be chosen via drop down menu. Uninstall Btrfs Assistant and snapper packages or might get errors about snapper services. Don’t expect any support :sweat_smile:
Thanks for the tip @jfontane, and welcome to the community. This seems like a good place to close down this old thread.
