Hello Garuda users.
usually the popup should be on the top right corner ,
but it keeps changing it's position to another position
I tried community/notify-osd
, notification banner reloaded, and notify-osd at the recommendation of @Technetium, but it did not help.
Here is a temporary link to a short video of it happening: https://files.catbox.moe/dfwvlu.webm
Garuda inxi :
╭─[email protected] in ~ took 115ms
╰─λ garuda-inxi
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fa7b94ce-8405-4a0c-afc8-cdef6b86182f rw [email protected]
loglevel=3 ibt=off
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HP product: HP EliteBook 840 G4 v: N/A
Mobo: HP model: 828C v: KBC Version 45.52 serial: <superuser required>
UEFI: HP v: P78 Ver. 01.45 date: 12/15/2022
ID-1: BAT0 charge: 11.0 Wh (24.8%) condition: 44.3/51.3 Wh (86.4%)
volts: 11.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 565
Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF2
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1800 high: 2700 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 2700 3: 900
4: 2700 bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:3 chip-ID: 05c8:0397 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x123d built: 2013 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api tools: N/A
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
address: <filter>
Local Storage: total: 238.47 GiB used: 7.6 GiB (3.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAV256TBN-1AR15ABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0T12 scheme: GPT
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 6.15 GiB (20.5%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 207.99 GiB size: 207.99 GiB (100.00%)
used: 1.45 GiB (0.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
used: 6.15 GiB (20.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-5: /var/tmp raw-size: 30 GiB size: 30 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C pch: 32.5 C mobo: N/A
Processes: 220 Uptime: 5m wakeups: 3 Memory: available: 7.64 GiB
used: 1.69 GiB (22.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1188
libs: 357 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-05-15
Last full system update: 2023-05-15
