Popsible.AppImage installed by Garuda Downloader not launching
Hello Everyone
System specs below:
  Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=ec489aa3-7718-4f5a-a2f5-6b5cf5fcc05c rw rootflags=subvol=@
    resume=UUID=46fc93e1-4b61-4909-957a-cb270436e283 loglevel=3 pci=realloc
  Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.5 info: latte-dock
  Type: Laptop System: Micro-Star product: GS66 Stealth 10UG v: REV:1.0
  Mobo: Micro-Star model: MS-16V3 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16V3IMS.111 date: 09/28/2021
  ID-1: BAT1 charge: 88.6 Wh (93.0%) condition: 95.3/95.0 Wh (100.4%)
    volts: 16.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: N/A
  Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
    stepping: 2 microcode: 0xF0
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
    bogomips: 70399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nvidia v: 515.48.07
    alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
  Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:3
    chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
    unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
  Monitor-1: eDP-1 model: AU Optronics 0x328e built: 2019 res: 1920x1080
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.1
    direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
  Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
  Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2725
  IF: wlp61s0 state: up mac: <filter>
  Device-2: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: N/A bus-ID: 3e:00.0 chip-ID: 8086:3101 class-ID: 0200
  IF: enp62s0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-14:4 chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 2.77 TiB used: 39.53 GiB (1.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 1TB
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
    temp: 40.9 C scheme: GPT
    model: PC SN720 SDAQNTX-2T00-1032 size: 1.86 TiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 10204122 temp: 45.9 C scheme: GPT
  ID-1: / raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
    used: 39.53 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
  ID-3: /home raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
  ID-4: /var/log raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.17 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:9
  System Temperatures: cpu: 57.0 C pch: 48.0 C mobo: N/A
  Processes: 354 Uptime: 53m wakeups: 1 Memory: 31.17 GiB used: 5 GiB (16.0%)
  Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1540 lib: 374 Shell: fish
  v: 3.4.1 running-in: alacritty inxi: 3.3.18
Garuda (2.6.4-1):
  System install date:     2022-06-20
  Last full system update: 2022-06-21 ↻
  Failed units:            nmb.service
I have been trying to use Garuda Downloader. One issue I notice is that the insallted popsicle.AppImage does not execute. Executing it from the command line gives the following errors:
Gtk-Message: 15:11:39.148: Failed to load module "canberra-gtk-module"
Gtk-Message: 15:11:39.148: Failed to load module "appmenu-gtk-module"
'g_io_module_load': /usr/lib/gio/modules/libgioenvironmentproxy.so: undefined symbol: g_io_module_load
Failed to load module: /usr/lib/gio/modules/libgioenvironmentproxy.so
/usr/lib/gio/modules/libgiognomeproxy.so: undefined symbol: g_task_set_name
Failed to load module: /usr/lib/gio/modules/libgiognomeproxy.so
/usr/lib/gio/modules/libgiognutls.so: undefined symbol: g_tls_channel_binding_error_quark
Failed to load module: /usr/lib/gio/modules/libgiognutls.so
/usr/lib/gio/modules/libgiolibproxy.so: undefined symbol: g_task_set_name
Failed to load module: /usr/lib/gio/modules/libgiolibproxy.so
Gtk-Message: 15:11:39.210: Failed to load module "colorreload-gtk-module"
Gtk-Message: 15:11:39.210: Failed to load module "window-decorations-gtk-module"
Gtk-Message: 15:11:39.210: Failed to load module "appmenu-gtk-module"
(Popsicle:12723): Gtk-WARNING **: 15:11:39.252: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
Gtk:ERROR:/build/gtk+3.0-NmdvYo/gtk+3.0-3.22.11/./gtk/gtkiconhelper.c:493:ensure_surface_for_gicon: assertion failed: (destination)
Bail out! Gtk:ERROR:/build/gtk+3.0-NmdvYo/gtk+3.0-3.22.11/./gtk/gtkiconhelper.c:493:ensure_surface_for_gicon: assertion failed: (destination)
I have tried reinstalling appmenu-gtk-module to no avail.
So I don't quite understand the module errors. Can someone please help get popsicle.AppImage running for me to use with the isos downloaded by Garuda-Downlaoder?
First reboot then use
pacman -Syu popsicle
Thanks. I did this, but I presume this is to remove the dependency on the Garuda-downloader and use popsicle without appimage.
In any case, it works to do it this way, so will mark solved (if i can figure out how to, being new here..)
It's weird that the Appimage would fail, after all these are supposed to run by itself :face_with_monocle: gotta look into it.
