Poor performance in some games, as well as NVIDIA xserver setting seems to be missing alot
I’ve been having some pretty terrible stuttering and screen tearing. It seems to only happen on a few games, and while digging through the forum trying to find a solution, it seems the Xserver setting is missing a lot of options. I’m pretty sure it’s not a performance issue as The Division 2 and Exanima will run relatively fine, but Stardew Valley and City Skylines 2 run absolutely terrible. I will also get a ton of errors in the terminal when trying sudo nvidia-settings.
I’m very new at this so apologies in advance.
Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=855a0823-4983-43a3-841e-913b19e17268 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F11
date: 10/15/2019
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2313 high: 4904 min/max: 800/4900 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 4904 3: 800
4: 4801 5: 800 6: 4802 7: 800 8: 800 bogomips: 57600
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-3,HDMI-A-1 empty: DP-1,DP-2,Unknown-2 bus-ID: 01:00.0
chip-ID: 10de:1e81 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
x11: drv: swrast inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:1e81
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f8
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.2:14 chip-ID: 8087:0029
Report: btmgmt ID: hci1 rfk-id: 3 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Device-2: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:8771
Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.93 TiB used: 141.31 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 28.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SP580 size: 111.79 GiB
serial: <filter> fw-rev: 0.5 scheme: GPT
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
used: 141.31 GiB (15.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C pch: 37.0 C mobo: N/A
Processes: 282 Uptime: 25m wakeups: 0 Memory: total: 16 GiB
available: 15.55 GiB used: 2.82 GiB (18.1%) Init: systemd v: 255
pm: pacman pkgs: 1607 libs: 500 tools: octopi,pamac,paru Shell: fish
v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-12-08
Last full system update: 2023-12-11 ↻
nvidia-settings log
** (nvidia-settings:27093): WARNING **: 03:30:06.588: Unable to connect to dbus: Error spawning command line “
dbus-launch --autolaunch=76bd59753f474e82822ea3f3efa72c40 --binary-syntax --close-stderr”: Child process exite
d with code 1
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.598: g_object_unref: assertion 'G_IS_OBJECT (objec
t)' failed
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.614: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (wi
dget)' failed
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.617: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (wi
dget)' failed
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.618: invalid (NULL) pointer instance
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.618: g_signal_handlers_block_matched: assertion 'G
_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.618: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE
_BUTTON (toggle_button)' failed
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.618: g_signal_handlers_unblock_matched: assertion
'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.618: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (wi
dget)' failed
dget)' failed
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.619: invalid (NULL) pointer instance
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.619: g_signal_handlers_block_matched: assertion 'G
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.619: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.619: g_signal_handlers_unblock_matched: assertion
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.620: invalid (NULL) pointer instance
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.620: g_signal_handlers_block_matched: assertion 'G
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.620: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE
(nvidia-settings:27093): GLib-GObject-CRITICAL **: 03:30:06.620: g_signal_handlers_unblock_matched: assertion
(nvidia-settings:27093): Gtk-CRITICAL **: 03:30:06.620: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (wi
dget)' failed
dget)' failed
(nvidia-settings:27093): GLib-GIO-CRITICAL **: 03:30:06.643: g_dbus_connection_register_object: assertion 'G_I
S_DBUS_CONNECTION (connection)' failed
(nvidia-settings:27093): GLib-GIO-CRITICAL **: 03:30:06.644: g_dbus_connection_register_object: assertion 'G_I
(nvidia-settings:27093): GLib-GIO-CRITICAL **: 03:30:06.644: g_dbus_connection_get_unique_name: assertion 'G_I
I forgot to mention that i have tried multiple different versions of proton, and adjusting various in game graphical settings.
Have you tried an X11 session? (You can change session type on the login screen)
It worked! I’m still getting some errors but after I re download some games and try some stuff out, I will report back.
remaining nvidia-settings errors:
** (nvidia-settings:79347): WARNING **: 04:07:50.500: Unable to connect to dbus: Error spawning command line “
d with code 1
(nvidia-settings:79347): GLib-GObject-CRITICAL **: 04:07:50.510: g_object_unref: assertion 'G_IS_OBJECT (objec
t)' failed
(nvidia-settings:79347): GLib-GIO-CRITICAL **: 04:07:50.666: g_dbus_connection_register_object: assertion 'G_I
(nvidia-settings:79347): GLib-GIO-CRITICAL **: 04:07:50.666: g_dbus_connection_get_unique_name: assertion 'G_I
Can confirm everything is working great with minor in game tweaks.
