Hello.
Here's my garuda-inxi output
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=81f5b3ab-f331-4f94-901e-ff46f362f45c rw [email protected]
resume=UUID=139cd65e-f8e5-45e1-a276-00b5e25d6fb3 loglevel=3
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: Dell product: XPS 13 9360 v: N/A
Mobo: Dell model: 02PG84 v: A00 serial: <superuser required> UEFI: Dell
v: 2.7.1 date: 05/21/2018
ID-1: BAT0 charge: 33.7 Wh (100.0%) condition: 33.7/60.0 Wh (56.2%)
volts: 8.3 min: 7.6 model: SMP DELL TP1GT61 type: Li-poly serial: <filter>
status: Full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 787 high: 800 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 796 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 31999
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:7 chip-ID: 0c45:670c class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1184x285mm (46.6x11.2")
s-diag: 1218mm (47.9")
Monitor-1: DP1-1 res: 2560x1080 hz: 60 dpi: 97
size: 670x280mm (26.4x11.0") diag: 726mm (28.6")
Monitor-2: DP1-2 res: 1920x1080 hz: 60 dpi: 84
size: 580x240mm (22.8x9.4") diag: 628mm (24.7")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
bus-ID: 3a:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 4-1.4.2:4 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp57s0u1u4u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 1.82 TiB used: 35.86 GiB (1.9%)
rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 29.63 GiB (14.8%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 200 GiB size: 200 GiB (100.00%)
used: 29.63 GiB (14.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C pch: 40.5 C mobo: 31.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 357 Uptime: 48m wakeups: 2 Memory: 15.35 GiB
used: 5.65 GiB (36.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1476 lib: 352 Shell: fish
Garuda (2.5.4-2):
System install date: 2022-02-06
Last full system update: 2022-02-15
Problem I'm having is that I'm on a new installation of Garuda, first time user - have been on a vanilla Arch for the past 10 years.
I am using this machine as a dev box.
- I've installed poetry package (python-poetry) and pyenv;
- I installed python 3.8.12
- made python 3.8 "local" (pyenv local 3.8.12, poetry env use 3.8.12)
- have created a new virtual env (python3.8 -m venv .venv)
- once I run "poetry install", it crashes with a "Permission Denied".
Full error is below:
Installing dependencies from lock file
Package operations: 92 installs, 0 updates, 0 removals
• Installing pycparser (2.21): Failed
PermissionError
[Errno 13] Permission denied: '.venv/bin/pip'
at /usr/lib/python3.8/subprocess.py:1704 in _execute_child
1700│ else:
1701│ err_filename = orig_executable
1702│ if errno_num != 0:
1703│ err_msg = os.strerror(errno_num)
→ 1704│ raise child_exception_type(errno_num, err_msg, err_filename)
1705│ raise child_exception_type(err_msg)
1706│
1707│
1708│ def _handle_exitstatus(self, sts, _WIFSIGNALED=os.WIFSIGNALED,
I've racked my brains for the past 2 days, and I cannot understand why that is; file permissions are definitely correct.
Anybody having issues with python-poetry, or can advise how to fix it?
