Firstly 1, the system crashed, or more precisely, the screen flashed, and then it restarted, but this time the audio wasn’t working (don’t worry, my speakers are good). therefore I decided to restart.
2. I booted to many snapshots, and each one displayed the same error message: “failed to start remount root and file system.”
3. I tried to use the terminal, but nothing happened. Do I need to perform some magic to make it function? I mean, there’s a lot of long-winded gibberish on the Arch Wiki that I don’t understand.
Please take note that I am an absolute newbie who doesn’t know anything about Linux at all. I spend most of my time browsing the web and even i haven’t worked out how to play games on Linux the mean reason i choose garuda .
I believe it might have something to do with this issue from my search. 1. The other day, after updating, I received a prompt to “grub-install,” which I followed. Next, I received a command to update Grub 2. Some people claim that it’s UUIDs with the same value or output, which is, I believe, the bootloader for the posts with the dragon theme rather is grub than the login screen. I have no idea what the hell UUID is.
Clever choice, for both GNU/Linux and Garuda Linux.
First thing, you can always try to Google(or GPT) first. Here’s what I found in a manjaro forum.[1]
If you’ve partitioned your disk after installation, this might be the cause.
I myself is just a Garuda user, not from the official team. So, no warranty.
I wonder whether you can normally boot and enter the GUI.
What do you mean by use the terminal? Do you mean Ctrl+Alt+t to open konsole? (Maybe you can use Ctrl+Alt+F4 to a tty, a real terminal)
If you can open any term, plz contain the FULL output of garuda-inxi as instructed in the template which you are supposed to read before posting. (If you cannot open a term in GUI you can run something like garuda-inxi > ~/garuda-inxi.txt, then open dolphin(win+e) to open that file.)
What trouble are you trying to solve? I actually don’t quite get it. And I guess we are supposed to focus on one problem per thread?
You’ll be more expertise in searching such info with more experience, and you’ll one day understand those gibberish. But you have to always try searching on your own first to gain exp, keep going. ↩︎
the trouble i face is failed to start remount root and file system i can’t boot to my system
when the msg [FAILED] failed to start remount root and file system the line under it sames like i have the power to write in it but nothing happens i can’t write any command so yeah my mean trouble is 2
i can’t give the FULL output of garuda-inxi because i can’t use the terminal like i expland in 3 (sorry for the bad english i’m trying my best)
i see the manjaro one but to be honest i don’t really know what to do or i don’t understand blkid or fstab i follow the steps but i still don’t gat it
thx i’m reading about what is fstab and blkid and of course uuid (i will do some troubleshooting i found an youtube vid i will follow it’s step then i will see what will happen )
I see, I see. I don’t know if it’s okay if you write in your own language, as we all can translate, and that might make things clearer
E.g, I don’t understand what you mean by saying
So, possibly I guess that’s caused by a disk partition after installation. Did you do that, like deleting any partition to make the root partition bigger? Did you?
If you don’t have any data in the partition, maybe a re-installation is the quickest solution?
If you want to preserve some data, you can boot into the livecd you used to install garuda and copy them to somewhere, a net drive or another usb. You can even run cmds like garuda-inxi or fdisk -l and cat /etc/fstab and post their output here. Or, you can even chroot into it if you later know how repair~ Seems worth a try.
hello for some reason a now option showed in the bootmenu it’s called garuda (The name of my ssd) and i mange to boot to it but my old one is UFEI OS (The name of my ssd) can’t boot to it but the OS still is broking like the last one the audio won’t work and my desktop task menu ii rest for some reason i will try to boot to an older sanpshot
i can only boot to my broking OS can’t boot to an old snapshots and the old error msg [FAILED] failed to start remount root and file system the line under it sames like i
and a new one [FAILED] failed to unmount /tmp
and here is my garuda-inxi:
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
garuda maintenance telling me that an old sanpshots/backups found in infinity number of windows keep opening this my OS is dommed
old restore subvolumes @_backup(the data and some random numbers)
what to do 1. ignore permanent 2. delete 3. cancel
and maintenance recommend hotfix it’s doesn’t do anything when i click it and help button show the goal of the hotfix which is this Linux 5.16's autodefrag BTRFS regression
is it a save solution to go to .sanpshot and copy all the root files form an older sanpshot to my curren broken system and overwrite everything like windows?
i know about the snapper but i fugared maybe it will fix the plm and i can finally be able to boot back to an old snapshot because this broken one i can boot to it for some reason an like the sanpshots
Use your own language plz. It must be easier for me to read the translation to understand.
I don’t understand what you want. You wanna be able to boot into both snapshots?
thx bro trust me the translation will be worst then me but for now i’m gonna go get some sleep i have a university to go to goodnight thx for the hard work i hope i figured this out when i wake up good luck guys
Let’s both compromise. If you ever wanna anybody understand what you say, write in your own language, TRANSLATE it, and modify it if you like, finally put that text here.
Snapper tools is a perfect tool to switch between snapshots. Newer snapshots won’t be deleted if you use snapper tool in kde instead of in the grub
As for the sound thing. How are they look like, the configs of your sound? And the window pop out upon clicking this?
