```text
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e0aa6bf1-e32d-48b2-a659-01e4322f83f8
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=31f5f81c-4fb3-4a39-893a-3e7c25a0feb6 loglevel=3 ibt=off
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0 Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 27.9 Wh (68.9%) condition: 40.5/42.1 Wh (96.4%) volts: 11.8 min: 11.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 240
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/4056 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1400 3: 1400 4: 1400 5: 1397 6: 1400
7: 1400 8: 1400 9: 1397 10: 1400 11: 1400 12: 1400 bogomips: 50304
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 41.0 C
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-3:3
chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 compositor: gnome-shell
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: ZTE WCDMA MSM DEMO Mobile Boardband type: USB driver: cdc_ether,usb-storage
bus-ID: 1-3:3 chip-ID: 19d2:1405 class-ID: 0806 serial: <filter>
IF: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2 chip-ID: 8087:0032
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
Local Storage: total: 491.84 GiB used: 26.55 GiB (5.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
rev: FXV7101Q temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer size: 14.9 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.56 GiB (4.5%) fs: btrfs
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 608 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 5.43 GiB (1.7%) fs: btrfs
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.56 GiB (4.5%) fs: btrfs
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.56 GiB (4.5%) fs: btrfs
ID-1: swap-1 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): cpu: 0
Processes: 387 Uptime: 2m wakeups: 1 Memory: 7.15 GiB used: 2.54 GiB (35.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1305
libs: 353 tools: pamac,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.25
System install date: 2022-12-05
Last full system update: 2023-03-29
I've just done an update and Plymouth was one of the things that was updated.
The following was displayed after the update:
warning: /etc/plymouth/plymouthd.conf installed as /etc/plymouth/plymouthd.conf.pacnew
WARNING: The 'plymouth-encrypt' and 'sd-plymouth' hooks are no longer exist in the package. You should replace them with 'encrypt' and 'plymouth' hooks in your 'mkinitcpio.conf'. The 'lxdm-plymouth.service', 'lightdm-plymouth.service' and 'sddm-plymouth.service' systemd service files are no longer exist in the package. You should enable 'lxdm.service', 'lightdm.service' or 'sddm.service' instead.
New optional dependencies for plymouth
gtk3: x11 renderer [installed]
I rebooted after the update, and during the reboot it mentioned something about fonts, but everything seems OK.
Is there something I should be concerned about?
