Please help my wifi is not working in macbook air 2016 broadcom wifi
help my wifi is not working in broadcom BCM4360 802.11AC DUAL BAND this is my wifi
We need your detailed specs, with the output of garuda-inxi, as required in the topic template.
If you don’t have an Ethernet connection, use your mobile phone in tethering.
You will need it anyway, since most likely it is a matter of installing the right driver.
First of all, when connected in tethering, update your system (this could be enough sometimes) with:
garuda-update
If that doesn’t help, there are many solutions in our forum for your chipset. I’d start from this one, whose solution did not require connectivity probably:
hwinfo --netcard --bluetooth | grep -Ei “(speed|hotplug|model|status|cmd|file|detected|driver:)” | grep -v “Config S”
Model: “Broadcom BCM4360 802.11ac Wireless Network Adapter”
Driver: “bcma-pci-bridge”
Driver Status: bcma is active
Driver Activation Cmd: “modprobe bcma”
Model: “OPPO Electronics RMX2001”
Hotplug: USB
Driver: “rndis_host”
Device File: enp0s20u1u4
Speed: 480 Mbps
Link detected: yes
Driver Status: rndis_host is active
Driver Activation Cmd: “modprobe rndis_host”
sudo systemctl stop NetworkManager; sudo modprobe -r wl; sudo modprobe -r brcmfmac; sleep 3; sudo modprobe brcmfmac; sudo systemctl start NetworkManager
Hotplug: USB
Speed: 480 Mbps
Link detected: yes
If that didn’t help (after a reboot), try the Broadcom proprietary driver:
sudo pacman -Syu broadcom-wl-dkms
thanks very much bro for help now its working
have a great day
A post was split to a new topic: How to reduce trackpad scrolling sensivity
Please open a dedicated topic for this.
We need to keep the forum “tidy” to help future searchers.
