Hi everyone I could use some help, I have an audio device plugged into my front and back port and i like them to be linked together and play the same audio, usually i go into alsamixer on ubuntu and mint, and disable the auto mute and the issue is solved but when i do that on garuda all it does is allow me to switch between front and back port but it doesn't play audio on both at the same time
If you select the "Pro Audio" profile then PipeWire will output to all jacks.
For example, using pavucontrol
doesnt seem to work it just forces the audio to the back port
Well switch to pulseaudio and use paprefs it has option to simultaneously play from all devices
sudo Pacman -S pulseaudio-support pulseaudio-bluetooth paprefs
Then Open paprefs
There will be a way of doing it with PipeWire, e.g. PipeWire/Examples - ArchWiki shows how to split jacks into separate output sinks.
well i tried that and went to simultaneous output and enabled it, and that still didnt work, i did see a virtual output in pavucontrol but selecting that didnt work this is the second garuda installation that does it so id assume this issue is built into garuda somehow.
and i have no clue what im supposed to use from that, im not a coder, im a bit of a newb
Don’t make it a bigger deal than it warrants. It’s not magic. All you are doing is altering/creating a text file. The Arch Wiki link is just a guide with suggestions. Play around with them. See what you can achieve. You can always revert changes.
Read more here:
This isn’t “easy” yet, but that’s what you get for having an operating system that exposes everything to the user.
This is a good opportunity to learn.
Same boat here, except I am a "coder" and experienced Linux user on many platforms. This is a colossal pain in Garuda Linux (doing anything with NVM is also a HUGE pain - FISH is pretty, but no good for developers - but I digress). This is the second installation I have had on my machine since it allowed me to quit dual-booting as I no longer needed Windoze to play games but this is one of the drawbacks. With greater control comes greater headaches. I would very much like to know if this has been solved.
Please open new post and follow the template, thanks.
