Application: plasmashell (plasmashell), signal: Segmentation fault
Content of s_kcrashErrorMessage: std::unique_ptr<char []> = {get() = <optimized out>}
warning: Can't open file /memfd:xshmfence (deleted) during file-backed mapping note processing
warning: Can't open file anon_inode:i915.gem during file-backed mapping note processing
[New LWP 3414]
[New LWP 3430]
Downloading 8.31 M separate debug info for /usr/lib/libKirigamiPlatform.so.6...
Downloading 1.01 M separate debug info for /usr/lib/libKF6Style.so.6...
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `/usr/bin/plasmashell --version'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 __pthread_kill_implementation (threadid=<optimized out>, signo=signo@entry=11, no_tid=no_tid@entry=0) at pthread_kill.c:44
44 return INTERNAL_SYSCALL_ERROR_P (ret) ? INTERNAL_SYSCALL_ERRNO (ret) : 0;
[Current thread is 1 (Thread 0x73a9c8760a40 (LWP 3414))]
Cannot QML trace cores :(
/usr/share/drkonqi/gdb/python/gdb_preamble/preamble.py:547: DeprecationWarning: datetime.datetime.utcfromtimestamp() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.fromtimestamp(timestamp, datetime.UTC).
boot_time = datetime.utcfromtimestamp(psutil.boot_time()).strftime('%Y-%m-%dT%H:%M:%S')
Downloading 145.00 K source file /usr/src/debug/qt6-base/qtbase/src/widgets/kernel/qapplication.cpp...
Downloading 201.12 K source file /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qobject.cpp...
Downloading 1.75 K source file /usr/src/debug/qt6-base/qtbase/src/plugins/platforms/xcb/qxcbscrollingdevice_p.h...
Downloading 30.97 K source file /usr/src/debug/qt6-base/qtbase/src/gui/kernel/qpointingdevice.cpp...
Downloading 12.53 K source file /usr/src/debug/qt6-base/qtbase/src/gui/kernel/qinputdevice.cpp...
Downloading 37.49 K source file /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qlist.h...
Downloading 14.87 K source file /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qcontainertools_impl.h...
Downloading 19.44 K source file /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qarraydatapointer.h...
/usr/share/drkonqi/gdb/python/gdb_preamble/preamble.py:564: DeprecationWarning: datetime.datetime.utcnow() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.now(datetime.UTC).
'timestamp': datetime.utcnow().isoformat(),
Thread 2 (Thread 0x73a9c7a8e6c0 (LWP 3430)):
#0 __syscall_cancel_arch () at ../sysdeps/unix/sysv/linux/x86_64/syscall_cancel.S:56
#1 0x000073a9ce69fe33 in __internal_syscall_cancel (a1=a1@entry=127173036399080, a2=a2@entry=1, a3=a3@entry=-1, a4=a4@entry=0, a5=a5@entry=0, a6=a6@entry=0, nr=7) at cancellation.c:49
#2 0x000073a9ce69fe74 in __syscall_cancel (a1=a1@entry=127173036399080, a2=a2@entry=1, a3=a3@entry=-1, a4=a4@entry=0, a5=a5@entry=0, a6=a6@entry=0, nr=7) at cancellation.c:75
#3 0x000073a9ce71a53e in __GI___poll (fds=fds@entry=0x73a9c7a8d9e8, nfds=nfds@entry=1, timeout=timeout@entry=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
#4 0x000073a9d17a820b in poll (__timeout=-1, __nfds=1, __fds=0x73a9c7a8d9e8) at /usr/include/bits/poll2.h:39
#5 _xcb_conn_wait (c=c@entry=0x56718926e0e0, vector=vector@entry=0x0, count=count@entry=0x0, cond=<optimized out>) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_conn.c:510
#6 0x000073a9d17a9f3d in _xcb_conn_wait (count=0x0, vector=0x0, cond=0x56718926e120, c=0x56718926e0e0) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_conn.c:476
#7 xcb_wait_for_event (c=0x56718926e0e0) at /usr/src/debug/libxcb/libxcb-1.17.0/src/xcb_in.c:703
#8 0x000073a9c83accb9 in QXcbEventQueue::run (this=0x567189266d90) at /usr/src/debug/qt6-base/qtbase/src/plugins/platforms/xcb/qxcbeventqueue.cpp:192
#9 0x000073a9ceed8a9b in operator() (__closure=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:375
#10 (anonymous namespace)::terminate_on_exception<QThreadPrivate::start(void*)::<lambda()> > (t=...) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:311
#11 QThreadPrivate::start (arg=0x567189266d90) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:339
#12 0x000073a9ce6a370a in start_thread (arg=<optimized out>) at pthread_create.c:448
#13 0x000073a9ce727aac in __GI___clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 1 (Thread 0x73a9c8760a40 (LWP 3414)):
[KCrash Handler]
#5 QArrayDataPointer<QInputDevice const*>::data (this=0x0) at /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qcontainertools_impl.h:387
#6 QArrayDataPointer<QInputDevice const*>::constEnd (this=0x0) at /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qarraydatapointer.h:127
#7 QList<QInputDevice const*>::cend (this=0x0) at /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qlist.h:644
#8 QtPrivate::sequential_erase_one<QList<QInputDevice const*>, QInputDevice const*> (c=..., t=<synthetic pointer>: <optimized out>) at /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qcontainertools_impl.h:389
#9 QList<QInputDevice const*>::removeOne<QInputDevice const*> (this=0x0, t=<synthetic pointer>: <optimized out>) at /usr/src/debug/qt6-base/qtbase/src/corelib/tools/qlist.h:613
#10 QInputDevicePrivate::unregisterDevice (dev=0x56718929bdd0) at /usr/src/debug/qt6-base/qtbase/src/gui/kernel/qinputdevice.cpp:360
#11 0x000073a9cf5cfa1f in QInputDevice::~QInputDevice (this=<optimized out>, this=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/gui/kernel/qinputdevice.cpp:110
#12 QPointingDevice::~QPointingDevice (this=<optimized out>, this=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/gui/kernel/qpointingdevice.cpp:168
#13 0x000073a9c83b3cb0 in QXcbScrollingDevice::~QXcbScrollingDevice (this=<optimized out>, this=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/plugins/platforms/xcb/qxcbscrollingdevice_p.h:29
#14 QXcbScrollingDevice::~QXcbScrollingDevice (this=<optimized out>, this=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/plugins/platforms/xcb/qxcbscrollingdevice_p.h:29
#15 0x000073a9ceda2e5e in QObject::event (this=0x56718929bdd0, e=0x56718929be80) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qobject.cpp:1403
#16 0x000073a9d0eff0ca in QApplicationPrivate::notify_helper (this=<optimized out>, receiver=0x56718929bdd0, e=0x56718929be80) at /usr/src/debug/qt6-base/qtbase/src/widgets/kernel/qapplication.cpp:3296
#17 0x000073a9ced55b00 in QCoreApplication::notifyInternal2 (receiver=0x56718929bdd0, event=event@entry=0x56718929be80) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1172
#18 0x000073a9ced55edc in QCoreApplication::sendEvent (receiver=<optimized out>, event=0x56718929be80) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1612
#19 QCoreApplicationPrivate::sendPostedEvents (receiver=0x0, event_type=52, data=0x567189252790) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1946
#20 0x000073a9cf02fc50 in QCoreApplication::sendPostedEvents (receiver=0x0, event_type=52) at /usr/src/debug/qt6-base/qtbase/src/corelib/kernel/qcoreapplication.cpp:1800
#21 operator() (__closure=<optimized out>) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:403
#22 (anonymous namespace)::terminate_on_exception<QThreadPrivate::finish()::{lambda()#1}>(QThreadPrivate::finish()::{lambda()#1}&&) [clone .isra.0] (t=...) at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:311
#23 0x000073a9ceed8515 in set_thread_data(QThreadData*)::Cleanup::~Cleanup() () at /usr/src/debug/qt6-base/qtbase/src/corelib/thread/qthread_unix.cpp:386
#24 0x000073a9ce64de00 in __cxa_finalize (d=0x73a9cf1f5000) at cxa_finalize.c:97
#25 0x000073a9ceccc3a8 in ?? () from /usr/lib/libQt6Core.so.6
#26 0x00007fffd07150c0 in ?? ()
#27 0x000073a9d1b6dfd2 in _dl_call_fini (closure_map=0x73a9d153b000) at dl-call_fini.c:43
Backtrace stopped: frame did not save the PC
Maybe you’ve already forgotten this:
Please read the topic template again:
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the \u201chide details\u201d feature)- Format terminal output (including your
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without an exact description - when, with what and under which circumstances the issue occurred - and without garuda-inxi this topic will be moved to 4xx Client Error > 412 Precondition Failed .
