Plasmashell[4447]: QImage::pixel: coordinate (9,13) out of range
I believe it’s the same error being briefly mentioned here Information for KDE users - KDE 6 available in Arch repos - #208 by Serqetry
I have hundreds of lines like the one in the title, with the coordinates changing.
Then this:
plasmashell[4447]: Plugin changed to: “org.kde.kwin.aurorae”
plasmashell[4447]: Searching for plugins: “org.kde.kwin.aurorae”
plasmashell[4447]: Factory: true
plasmashell[4447]: Module ‘org.kde.kwin.decoration’ does not contain a module identifier directive - it cannot be protected from external >
plasmashell[4447]: aurorae: Couldn’t find QML Decoration “”
plasmashell[4447]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:225:5: QML Connections: Implicitly define>
plasmashell[4447]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:220:5: QML Connections: Implicitly define>
plasmashell[4447]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyM>
Kernel: 6.11.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f643c5fc-4b1a-4bdc-a8ba-d2c33d4ab925 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Framework product: Laptop 16 (AMD Ryzen 7040 Series)
v: AJ serial: <filter> Chassis: type: 10 v: AJ serial: <filter>
Mobo: Framework model: FRANMZCP09 v: A9 serial: <filter>
part-nu: FRAGACCP0J uuid: 543c5b49-de17-ef11-be43-231024700020 UEFI: INSYDE
v: 03.03 date: 03/27/2024
ID-1: BAT1 charge: 80.1 Wh (89.8%) condition: 89.2/85.1 Wh (104.8%)
volts: 16.3 min: 15.5 model: NVT FRANDBA type: Li-ion serial: <filter>
status: discharging cycles: 8
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics socket: FP8 bits: 64
microcode: 0xA704104
Speed (MHz): avg: 1288 min/max: 400/5263 boost: enabled
base/boost: 4000/5250 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1288 2: 1288 3: 1288 4: 1288
5: 1288 6: 1288 7: 1288 8: 1288 9: 1288 10: 1288 11: 1288 12: 1288
13: 1288 14: 1288 15: 1288 16: 1288 bogomips: 127756
Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
XT/7600M XT/7600S/7700S / PRO W7600] vendor: Framework driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-33 built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1,Writeback-1,eDP-1
bus-ID: 03:00.0 chip-ID: 1002:7480 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Framework
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-4,eDP-2 empty: DP-2, DP-3, DP-5, DP-6, DP-7, DP-8, DP-9,
Writeback-2 bus-ID: c4:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 36.0 C
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 2880x3220 s-dpi: 96 s-size: 762x852mm (30.00x33.54")
s-diag: 1143mm (45")
Monitor-1: DP-4 pos: top-left model: Asus VE278 serial: <filter>
built: 2013 res: 2880x1620 hz: 60 dpi: 122 gamma: 1.2
Monitor-2: eDP-2 pos: primary,bottom-r model: BOE Display 0x0bc9
built: 2022 res: 2560x1600 hz: 165 dpi: 188 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 18.1.8 DRM 3.58 6.11.1-zen1-1-zen) device-ID: 1002:15bf
memory: 500 MiB unified: no
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: mesa radv v: 24.2.3-arch1.1
device-ID: 1002:15bf surfaces: xcb,xlib device: 1 type: discrete-gpu
name: AMD Radeon RX 7700S (RADV NAVI33) driver: mesa radv
v: 24.2.3-arch1.1 device-ID: 1002:7480 surfaces: xcb,xlib device: 2
v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib
vendor: Framework driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Definition Audio vendor: Framework driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.1 chip-ID: 1002:1640
vendor: Framework driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c4:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 16 GT/s lanes: 16 bus-ID: c4:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Framework Audio Expansion Card
lanes: 1 mode: 2.0 bus-ID: 1-2.3:12 chip-ID: 32ac:0010 class-ID: 0300
API: ALSA v: k6.11.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: n/a (root, process) with:
bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Info: services: iwd, NetworkManager, systemd-timesyncd
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:8 chip-ID: 0e8d:e616
Local Storage: total: 931.51 GiB used: 114.45 GiB (12.3%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 5d 0h cycles: 100
read-units: 669,879 [342 GB] written-units: 710,360 [363 GB]
used: 114.45 GiB (12.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 30.66 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.9 C mobo: 36.9 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
GPU: device: amdgpu temp: 36.0 C watts: 5.22 device: amdgpu temp: 32.0 C
mem: 36.0 C fan: 0 watts: 14.00
Memory: total: 32 GiB note: est. available: 30.66 GiB used: 8.04 GiB (26.2%)
Processes: 394 Power: uptime: 5h 16m states: freeze,mem,disk
suspend: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.25 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1837 libs: 576 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date:     2024-09-18
Last full system update: 2024-10-03 ↻
This means that a reboot is pending after the latest update.
Just in case…
Trust me… no amount of rebooting solves this problem :slight_smile:
I understand that this might be yet another “this is a problem with KDE and not Garuda” post?
