Plasma5-themes-sweet-full-git stopping system update
root=UUID=30152b31-d1ed-4eac-86ea-b33493f76700 rw rootflags=subvol=@
resume=UUID=ea6666c3-a7ac-47b5-b900-02dde9dbe696 loglevel=3 ibt=off
Type: Desktop Mobo: ASRock model: H310M-HDV serial: <superuser required>
UEFI: American Megatrends v: P1.40 date: 05/24/2018
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3489 high: 4402 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 4289 2: 4400 3: 800
4: 800 5: 4394 6: 800 7: 4402 8: 4402 9: 4389 10: 4398 11: 4401 12: 4398
bogomips: 76799
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:73ff
s-diag: 1052mm (41.43")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: right model-id: RTK 0x1d1a
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 1168mm (46") ratio: 16:9 modes:
max: 1024x768 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: ViewSonic VX2458-mhd serial: <filter> built: 2020 res: 1920x1080
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Cannon Lake PCH cAVS vendor: ASRock driver: snd_hda_intel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Barco Display Systems USBGH1XK
lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0600:2318 class-ID: 0300
Device-4: Trust GXT 232 Microphone
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 145f:0254 class-ID: 0300
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.75 TiB used: 1.5 TiB (40.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: MBR
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 740.1 GiB (40.1%)
used: 740.1 GiB (40.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 31.0 C pch: 47.0 C mobo: N/A gpu: amdgpu
temp: 57.0 C mem: 68.0 C
Fan Speeds (rpm): fan-1: 858 fan-2: 1516 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 0
Processes: 313 Uptime: 17m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 4.76 GiB (30.6%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1516
pm: pacman pkgs: 1509 libs: 472 tools: octopi,paru pm: flatpak pkgs: 7
Shell: fish v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole
inxi: 3.3.31
Garuda (2.6.17-1):
System install date:     2023-11-02
Last full system update: 2023-11-02
Is partially upgraded:   Yes
Hello i am new to this sorry if i do something wrong, I have already looked at similar posts but it’s not exactly the same problem
If there is no easy fix i would like to know what steps i should take to remove the troublesome package considering i use a lot of sweet theme stuff on the active session, thank you.
╰─λ garuda-update
[sudo] password for kry:
:: Synchronising package databases...
garuda                                 96,6 KiB   271 KiB/s 00:00 [------------------------------------] 100%
core is up to date
extra is up to date
multilib is up to date
chaotic-aur                             2,6 MiB  4,08 MiB/s 00:01 [------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..šŸµ
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
warning: garuda-video-linux-config: local (2:1.1.4-4) is newer than garuda (1:r63.2f652e8-3)
resolving dependencies...
Packages (3) garuda-wallpapers-r87.6612cb0-1  grub-theme-garuda-dr460nized-r3.b40584e-1
plasma5-themes-sweet-full-git-r341.79f848a-1
Total Download Size:   66.26 MiB
Total Installed Size:  79.12 MiB
Net Upgrade Size:       0.00 MiB
:: Retrieving packages...
grub-theme-garuda-dr460nized-r3....  1601.8 KiB  2.39 MiB/s 00:01 [------------------------------------] 100%
garuda-wallpapers-r87.6612cb0-1-any    64.7 MiB  9.09 MiB/s 00:07 [------------------------------------] 100%
Total (2/2)                            66.3 MiB  8.97 MiB/s 00:07 [------------------------------------] 100%
(3/3) checking keys in keyring                                     [------------------------------------] 100%
(3/3) checking package integrity                                   [------------------------------------] 100%
(3/3) loading package files                                        [------------------------------------] 100%
(3/3) checking for file conflicts                                  [------------------------------------] 100%
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/calendar-selected.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/calendar-selected@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-active-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-active-dark@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-active.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-active@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-backdrop-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-backdrop-dark@2.png existsin filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-backdrop.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-backdrop@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-dark@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-hover-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-hover-dark@2.png exists infilesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-hover.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-hover@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-backdrop-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-backdrop-dark@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-backdrop.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-backdrop@2.pngexists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-dark.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive-dark@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked-insensitive@2.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/assets/checkbox-checked.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/xfwm4/top-right-active.png exists in filesystem
plasma5-themes-sweet-full-git: /usr/share/themes/Sweet-Dark/xfwm4/top-right-inactive.png exists in filesystem
Had to cut the pork but it’s more of the same
An error occurred: Body is limited to 32000 characters; you entered 105588.
Welcome :slight_smile:
Make a snapshot (fresh install, dosnt matter :slight_smile: ), open Konsole,
sudo pacman -Syu --overwrite '*'
after that use garuda-update again. For
System updated! 🐧
It would be nice to know WHY these packages exist in the filesystem already. Did you do any kind of moving files around manually or is this caused by another thing?
Hi thanks for replying, this is not a fresh install i have been lurking for about a year.
I will assume your solution is a nuke or something and wait for confirmation (god forbid i check on my own).
Hi thanks for replying, I know for certain that anything with a name5 on my system replaced something of the same name during the past month while performing standard garuda-update.
As for the other packages they can be updated normally if i use
garuda-update -- --ignore plasma5-themes-sweet-full-git
and do not contribute to the problem (checked right now).
Mhhh :eyes: :face_with_open_eyes_and_hand_over_mouth: :thinking:
Lmao that got a good chuckle out of me, oops can’t upload screenshot of my root folder being made in march (still wrong date xd)… and file properties being partially in greek???
Ok this worked (let’s pretend i studied what it would do before trying it) thank you for your time.
Last time I’ve seen this it was a deleted pacman log file, is that the case by any chance?
If I recall correctly, the system install date is determined from the first entry in the log file (/var/log/pacman.log), and some ā€œcleanupā€ software (bleachbit and others) reclaim disk space by deleting caches and logs a bit too aggressively.
Lol, and i still remenber the install like it was just couple month ago :joy: :joy:
Just altered the date of first line in pacman,log
System install date:        1923-08-23
Last full system update:    2023-11-08
Indeed i just used the included system cleaner…which i am failing to locate and can’t name…
I believe you are thinking of Stacer. It was recently taken out of Garuda Welcome because it was causing issues on certain systems, I don’t remember the specific details but that may be why you are having trouble finding it. You should be able to bring it up if you search for it by name with your launcher.
