As stated above plasma shell keeps crashing on my device. It happens in every fresh boot to plasma wayland, whenever kwin wants to draw a popup. Strangely it only occurs when kwin tries to draw the window on my 2nd external display. It was fine before and only experiencing these crashes for past week. It doesn’t crash in the laptop display, only in the external one. I’m using garuda dragonised for nearly 2 years and the wayland one for past 8 or so months but didn’t had any issue. As my past install of garuda was heavily customized, I replaced it with the kde light one but same thing is happening here. I have tried the default arch kernel and the lts one but no luck. Oh and it only happens in the wayland session, X11 one is completely fine.
Here’s the inxi
Kernel: 6.6.18-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=83f42e79-bc3c-4691-bf07-3e0c9c1a04d8 rw rootflags=subvol=@
resume=UUID=b926935b-dbc4-430f-9b03-fd5053c73759 quiet loglevel=3
udev.log_priority=3 ibt=off
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IC_FA506IC
Mobo: ASUSTeK model: FA506IC v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FA506IC.302
date: 12/28/2022
ID-1: BAT1 charge: 70.8 Wh (100.0%) condition: 70.8/90.2 Wh (78.4%)
volts: 16.6 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 400 min/max: 400/4300 scaling: driver: amd-pstate-epp
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
16: 400 bogomips: 92686
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 545.xx+ status: current (as of
2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 43.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2023 res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
API: ALSA v: k6.6.18-1-lts status: kernel-api tools: N/A
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 953.88 GiB used: 189.53 GiB (19.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SKC3000S512G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 26.9 C
ID-1: / raw-size: 54 GiB size: 54 GiB (100.00%) used: 10.93 GiB (20.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 418.44 GiB size: 418.44 GiB (100.00%)
used: 90.8 GiB (21.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:6
ID-4: /var/log raw-size: 54 GiB size: 54 GiB (100.00%)
used: 10.93 GiB (20.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-5: /var/tmp raw-size: 54 GiB size: 54 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:5
ID-2: swap-2 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.9 C mobo: 32.0 C gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): cpu: 2200
Memory: total: 16 GiB note: est. available: 15.05 GiB used: 1.66 GiB (11.1%)
Processes: 391 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
image: 6.01 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 938 libs: 293 tools: octopi,paru Compilers: N/A
Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-21
Last full system update: 2024-02-24
