Plasma desktop GUI not working
Hello Garuda users.
I was working normally and suddenly my computer freezed after restarting all plasma widgets crashed and some widgets are visible but not able to interact, the wallpaper turned in black, the latte dock is missing and the top bar too.
This is what my desktop looks like: check this out
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=9800f45c-6180-41c0-8046-eb00a3821dc0 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Dell product: G7 7588 v: N/A
Mobo: Dell model: 075F7T v: A00 serial: <superuser required> UEFI: Dell
v: 1.21.0 date: 04/15/2022
ID-1: BAT0 charge: 26.6 Wh (100.0%) condition: 26.6/56.0 Wh (47.5%)
volts: 16.8 min: 15.2 model: Samsung SDI DELL W7NKD87 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1966 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 800
bogomips: 52799
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:6718
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x63ed built: 2017 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 3b:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp59s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth0e4263b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-3: vethd946af1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 342.81 GiB used: 53.88 GiB (15.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
serial: <filter> fw-rev: 4R24 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 128GB
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 53.86 GiB (45.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 27 MiB (9.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.31 GiB used: 512 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 71.0 C pch: 47.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 332 Uptime: 29m wakeups: 13279 Memory: available: 15.32 GiB
used: 4.93 GiB (32.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1342
libs: 364 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-19
Last full system update: 2023-06-30 ↻
I just created a new user and the desktop works normally, what would it the ploblem be?
A configuration file somewhere in your home folder got corrupted and created the gui issue.
But this is probably the effect, the cause is probably in the freeze, and the root cause of the freeze to be defined.
Try to search in the logs at around the time when this happened.
By-the-way, given your install date, your dock is a plasma panel, latte-dock is not used anymore (and would have been a likely root cause).
I stopped plasma and i started nad throwed me this:
Checking screens: available: (QScreen(0x557b5c10bad0, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x557b5c10bad0, name="eDP-1"))
kf.plasma.quick: Applet preload policy set to 1
file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 10. Use 'sequences: [ <key> ]' to bind to all of them.
file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 9. Use 'sequences: [ <key> ]' to bind to all of them.
file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 8. Use 'sequences: [ <key> ]' to bind to all of them.
file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/main.qml:157:13: QML TextArea: Binding loop detected for property "implicitWidth"
file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
kf.config.core: couldn't lock local file
