Hello.
inxi -Faz
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5e3df3fe-8820-4ab8-80fe-eb97c317582f rw rootflags=subvol=@
Type: Laptop System: HP product: HP Laptop 14q-cs0xxx
Mobo: HP model: 849A v: KBC Version 74.37 serial: <superuser required>
UEFI: Insyde v: F.64 date: 07/23/2021
ID-1: BAT0 charge: 31.9 Wh (100.0%) condition: 31.9/31.9 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2258 high: 2300 min/max: 400/2300 scaling:
driver: intel_pstate governor: performance cores: 1: 2155 2: 2280 3: 2300
4: 2300 bogomips: 18399
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b67f class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:4 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 238.47 GiB used: 36.42 GiB (15.3%)
model: PC SN520 SDAPNUW-256G-1006 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20120006 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 150.01 GiB size: 150.01 GiB (100.00%)
used: 36.35 GiB (24.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 69.6 MiB (27.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 150.01 GiB size: 150.01 GiB (100.00%)
ID-4: /var/log raw-size: 150.01 GiB size: 150.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 150.01 GiB size: 150.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 171.5 MiB (2.2%)
System Temperatures: cpu: 41.0 C pch: 38.0 C mobo: 0.0 C
Processes: 243 Uptime: 41m wakeups: 5 Memory: 7.63 GiB
used: 3.48 GiB (45.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1508 pacman: 1494 lib: 360 snap: 14
Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
I'm facing the following issues repeatedly, and am not sure if they are related:
- While logging in, Plasma doesn't work sometimes. The screen is completely blank and frozen, including mouse pointer if visible. The only remedy is to force restart
- When I force restart, often my
.config/kwinrcis replaced. I know this because it removes the lines used to open Application Launcher with Meta Key. So I have to manually add in those lines again - Twice after a force restart, my Latte Dock has stopped showing up.
latte-dock --restartdoesn't help, although it does mention that an instance is already running. Tried a number of solutions from this forum and even manjaro forum, but the only thing that has worked is using Garuda Assistant to reset latte-dock configuration to default
I am happy to provide more details as necessary, but not sure which details would be relevant, hence just posting the problems. Also not sure of the prevalence of this problem/
