After the upgrade, my HDR toggle is missing in the Display Settings. To fix this, open your /etc/enviroment file and add this line
KWIN_DRM_ALLOW_NVIDIA_COLORSPACE=1
Then
sudo systemctl restart --now sddm
Kernel: 6.11.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ff0ab206-a76f-4c49-8f9f-1edbb4d49076 rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.6.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3607 date: 03/22/2024
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1743 min/max: 550/5084 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1743 2: 1743 3: 1743
4: 1743 5: 1743 6: 1743 7: 1743 8: 1743 9: 1743 10: 1743 11: 1743 12: 1743
13: 1743 14: 1743 15: 1743 16: 1743 17: 1743 18: 1743 19: 1743 20: 1743
21: 1743 22: 1743 23: 1743 24: 1743 25: 1743 26: 1743 27: 1743 28: 1743
29: 1743 30: 1743 31: 1743 32: 1743 bogomips: 217189
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: PNY driver: nvidia
v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-2 empty: DP-1, DP-3, HDMI-A-1,
Unknown-2 bus-ID: 07:00.0 chip-ID: 10de:1e87 class-ID: 0300
Device-2: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 328f:006d
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2080 driver: nvidia v: 560.35.03
device-ID: 10de:1e87 surfaces: xcb,xlib,wayland
Device-1: NVIDIA TU104 HD Audio vendor: PNY driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:10f8
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.11.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0616 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0489:e0e2
Local Storage: total: 28.34 TiB used: 14.8 TiB (52.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 6B0Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000DM001-1ER166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC25 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM003-1ER162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Toshiba model: HDWR11A size: 9.1 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 0603 scheme: GPT
ID-7: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST8000DM002-1YW112
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DN01 scheme: GPT
ID-8: /dev/sdg maj-min: 8:96 vendor: Western Digital
model: WD60EDAZ-11U78B0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4009 scheme: GPT
used: 149.9 GiB (15.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 94.2 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 47.2 C mobo: 38.0 C
Memory: total: 96 GiB note: est. available: 94.2 GiB used: 7.31 GiB (7.8%)
Processes: 568 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 37.61 GiB services: org_kde_powerdevil,
Packages: 1923 pm: pacman pkgs: 1911 libs: 537 tools: octopi,pamac,paru
pm: flatpak pkgs: 12 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-08-29
Last full system update: 2024-10-10
Relevant software: NetworkManager dracut nvidia-dkms
Tim
