I just installed the new GDG ISO from yesterday and added the KDE 6 repo to pacman.conf after doing the initial update after landing on the desktop and a couple of tweaks from the settings panel, rebooted, ran sudo pacman -Syy, then ran garuda-update and it refused to do the Plasma 6.0 update. I posted my Konsole output to GitHub. Any idea what might be going on? Thanks
╰─λ garuda-inxi
root=UUID=2213486d-fe2c-40cd-896e-3642e9775dfb rw rootflags=subvol=@
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2806
date: 10/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3953 high: 4202 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3854 5: 4192 6: 4196 7: 4194 8: 4193 9: 4035 10: 4202 11: 4180
12: 3591 bogomips: 86235
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 09:00.0
chip-ID: 1002:73ff class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
s-diag: 735mm (28.92")
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: AOC Q2963 serial: <filter>
built: 2016 res: 2560x1080 hz: 60 dpi: 97 gamma: 1.2
size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: max: 2560x1080
min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Local Storage: total: 26.04 TiB used: 15.13 TiB (58.1%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234100WD temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5980
serial: <filter> scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
used: 11.26 GiB (4.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 212 MiB (41.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.9 C mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 34.0 C
Processes: 386 Uptime: 18m wakeups: 4 Memory: total: 24 GiB
available: 23.35 GiB used: 4.33 GiB (18.5%) Init: systemd v: 254
pm: pacman pkgs: 1875 libs: 527 tools: octopi,pikaur,yay Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-30
Last full system update: 2023-10-30
