1 package management is handled in garuda compared to manjaro
2and how to find older kernel packages to download similarly to manjaro
I tried searching around, but these issues seem specific to garuda
and not other arch derivatives like manjaro
In manjaro you can easily find different version of the kernel using
sudo pacman -Ss linux515
or
sudo pacman -Ss linux510
and their respective headers with... linux515-headers
or something similar, and the dkms-nvidia module automatically
updates it's own headers to work seamlessly when switching kernel versions,
but in garuda you can only switch between different kernel versions that are
more recently released like 5.18 for example, with the install version being 5.15
I also noticed that in manjaro the chaotic aur repo's are disabled by default
whereas in garuda they are enabled by default, and most of the typical packages
people install are sourced from chaotic aur and aren't found in the typical repositories
I think it's a kind of awkward question to find an answer to using a search engine,
and was hoping someone that understood these issues could clarify them easily
it seems strange they have the same repositories but turn up completely
different results. I guess, simply, they are totally different.
I can tell you only how Garuda works, since my short experience with manjaro is too back in time.
As you have seen, we use Arch repos + the chaotic-aur, basically for the Garuda specific packages and for packages in the AUR deemed useful or requested by the user base to avoid them to build the packages.
Garuda is a pure rolling release, much closer to Arch than manjaro, so you'll get kernels only in their latest version.
If you really need to go back, see https://wiki.archlinux.org/title/Arch_Linux_Archive
You have hit on a misconseption.
Manjaro is not Arch. Ask them.
Comparing Manharo with Arch/Garuda is like comparing transportation delivery methods between one cars and one bicycles factory. They have many similarities, but also major differences.
