Dear all,
My pitivi video editor (extra/pitivi 2023.03-7) software does not start anymore, I get the following bash output:
ERROR - The following hard dependencies are unmet:
- Peas not found on the system
Missing soft dependency:
- cvtracker GStreamer element not found on the system
-> enables object tracking
I uninstalled the package and tried the package from AUR
yay -S pitivi-git
Unfortunately I get the same error message above when trying to start it.
Maybe someone has an idea on how to fix that problem.
inxi
Kernel: 6.12.24-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=34838ea6-aeea-438d-8f19-10531b4f934f rw rootflags=subvol=@
quiet resume=UUID=c50c5792-3f2c-4294-96b6-0c302904f2dc loglevel=3 ibt=off
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: Precision 5690 v: N/A
Mobo: Dell model: 0HFNKF v: A00 serial: <superuser required> part-nu: 0CC8
uuid: <superuser required> UEFI: Dell v: 1.4.0 date: 05/14/2024
ID-1: BAT0 charge: 79.9 Wh (94.1%) condition: 84.9/97.9 Wh (86.7%)
volts: 12.5 min: 11.6 model: BYD DELL JXM4G44L type: Li-poly
serial: <filter> status: discharging cycles: 81
Device-1: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Core Ultra 7 165H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4700:5000:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
bogomips: 135212
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 509x318mm (20.04x12.52")
s-diag: 600mm (23.63")
Monitor-1: eDP-1 model: BOE Display 0x0b99 built: 2022 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 1920x1200
API: Vulkan v: 1.4.309 layers: 7 device: 0 type: integrated-gpu name: Intel
Arc Graphics (MTL) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:7d55 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.4-arch1.1 (LLVM
19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
Info: Tools: api: vulkaninfo de: xfce4-display-settings
Device-1: Intel Meteor Lake IPU vendor: Dell driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 0000:00:05.0 chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Dell
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 0000:00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.12.24-1-lts status: kernel-api
Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
driver: iwlwifi v: kernel bus-ID: 0000:01:00.0 chip-ID: 8086:272b
IF: wlp1s0f0 state: up mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0036 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
class-ID: 0104
Local Storage: total: 2.79 TiB used: 86.57 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 2048GB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 36310129 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital model: PC SN810
NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 61912524 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 86.57 GiB (4.6%)
used: 624 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 86.57 GiB (4.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.8 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 22
ID-2: swap-2 type: partition size: 33.89 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.8 GiB used: 3.72 GiB (12.1%)
Processes: 450 Power: uptime: 55m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 12.31 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1914 libs: 455 tools: pamac,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.38
System install date: 2024-07-17
Last full system update: 2025-04-23 ↻
