Hello, posting after spending some time searching the forum, trying random things but have not been able to resolve this. I am trying to update Garuda. Instead of putting it into my own words, the output probably tells a better story:
root=UUID=31ddc345-0928-456b-bf48-5c86e845ba38 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: F2A88XN-WIFI v: x.x serial: <superuser required>
UEFI: American Megatrends v: F2 date: 12/16/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Info: model: AMD A10-7850K APU with Radeon R7 Graphics bits: 64 type: MT MCP
arch: Steamroller level: v2 built: 2014 process: GF 28nm family: 0x15 (21)
model-id: 0x30 (48) stepping: 1 microcode: 0x6003103
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3328 high: 3700 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2990 2: 3700
3: 3700 4: 2923 bogomips: 29545
Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel
alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm
built: 2013-17 ports: active: none empty: DVI-D-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:01.0 chip-ID: 1002:130f class-ID: 0300
Device-2: NVIDIA GM107GL [Quadro K1200] driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13bc class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia,radeon
alternate: fbdev,nv,vesa dri: radeonsi gpu: radeon,nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DP-1 pos: primary res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: None-2-1 size-res: N/A modes: N/A
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: Quadro K1200/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: Quadro K1200 driver: nvidia v: 545.29.02 device-ID: 10de:13bc
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:1308 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-4: GEMBIRD Honk HK-5002 USB Speaker
lanes: 1 mode: 1.1 bus-ID: 2-1:2 chip-ID: 1908:2070 class-ID: 0300
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Device-4: TP-Link Archer T2U PLUS [RTL8821AU] driver: rtl88XXau type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 2357:0120
IF: wlp0s16f0u2 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-3:2 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 1.36 TiB used: 82.96 GiB (5.9%)
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
used: 82.96 GiB (17.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 14.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 12.6 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 63 C fan: 46% device: radeon
temp: 16.0 C
Processes: 212 Uptime: 1h 14m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.57 GiB used: 3.33 GiB (22.9%) Init: systemd v: 254
pm: pacman pkgs: 1881 libs: 549 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-27
Last full system update: 2023-11-15
Total Installed Size: 6048.24 MiB
Net Upgrade Size: 25.51 MiB
(224/224) checking keys in keyring [------------------------------------] 100%
(224/224) checking package integrity [------------------------------------] 100%
(224/224) loading package files [------------------------------------] 100%
(224/224) checking for file conflicts [------------------------------------] 100%
/usr/share/man/man1/pw-loopback.1.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-avb.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-echo-cancel.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-fallback-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-filter-chain.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-loopback.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-netjack2-driver.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-netjack2-manager.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-pipe-tunnel.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-protocol-simple.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-rtp-sap.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-rtp-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-rtp-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-vban-recv.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man7/libpipewire-module-vban-send.7.gz exists in both 'pipewire-common-git' and 'pipewire-audio'
/usr/share/man/man5/pipewire-pulse.conf.5.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/libpipewire-module-protocol-pulse.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/libpipewire-module-pulse-tunnel.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-alsa-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-alsa-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-always-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-combine-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-echo-cancel.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-gsettings.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-jackdbus-detect.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-ladspa-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-ladspa-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-loopback.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-native-protocol-tcp.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-null-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-pipe-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-pipe-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-raop-discover.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-remap-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-remap-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-roc-sink-input.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-roc-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-roc-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-rtp-recv.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-rtp-send.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-simple-protocol-tcp.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-switch-on-connect.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-tunnel-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-tunnel-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-virtual-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-virtual-source.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-x11-bell.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-zeroconf-discover.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-module-zeroconf-publish.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/pipewire-pulse-modules.7.gz exists in both 'pipewire-common-git' and 'pipewire-pulse'
/usr/share/man/man7/libpipewire-module-x11-bell.7.gz exists in both 'pipewire-common-git' and 'pipewire-x11-bell'
/usr/share/man/man7/libpipewire-module-raop-discover.7.gz exists in both 'pipewire-common-git' and 'pipewire-zeroconf'
/usr/share/man/man7/libpipewire-module-raop-sink.7.gz exists in both 'pipewire-common-git' and 'pipewire-zeroconf'
/usr/share/man/man7/libpipewire-module-rtp-session.7.gz exists in both 'pipewire-common-git' and 'pipewire-zeroconf'
/usr/share/man/man7/libpipewire-module-zeroconf-discover.7.gz exists in both 'pipewire-common-git' and 'pipewire-zeroconf'
