Pipewire/pulse audio rebuild
I think they both need a rebuild? Maybe. They have been acting up since yesterday.
I’m not 100% on why i have pulse as I’ve only ever used pipewire. I’m guessing some pkg called for it?
garuda-update --skip-mirrorlist
[sudo] password for elite:
garuda is up to date
core                                  118.7 KiB   942 KiB/s 00:00 [-------------------------------------] 100%
extra                                   7.2 MiB  29.2 MiB/s 00:00 [-------------------------------------] 100%
multilib is up to date
chaotic-aur                           760.6 KiB  1406 KiB/s 00:01 [-------------------------------------] 100%
spawn pacman -Su
warning: material-kwin-decoration-git: local (0.0.7.r39.g0e989e5-1) is newer than chaotic-aur (r215.38718de-1)
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: pulseaudio-17.0-3 and pipewire-pulse-1:1.2.2-1 are in conflict
❯ garuda-inxi
Kernel: 6.10.1-2-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ed618e85-c1b1-4a62-9eef-7263837ec30d rw rootflags=subvol=@
resume=UUID=9e39bce2-8148-4e68-83a2-8185da8c85fb loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
UEFI: American Megatrends v: 4802 date: 06/15/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4064 high: 4328 min/max: 550/4426 boost: enabled
scaling: driver: amd-pstate-epp governor: performance cores: 1: 4301 2: 550
3: 4328 4: 4300 5: 4300 6: 4300 7: 4272 8: 4300 9: 4300 10: 4299 11: 4299
12: 4300 13: 4296 14: 4300 15: 4299 16: 4295 bogomips: 115203
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 0c:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 3127x1309 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.0-devel
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 GRE (radeonsi
navi31 LLVM 18.1.8 DRM 3.57 6.10.1-2-cachyos) device-ID: 1002:744c
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 GRE (RADV NAVI31) driver: mesa radv
v: 24.3.0-devel (git-cf9588bae6) device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: AMD Radeon RX 7900 GRE driver: amd v: (LLPC) device-ID: 1002:744c
18.1.8 256 bits) driver: mesa llvmpipe v: 24.3.0-devel (git-cf9588bae6)
(LLVM 18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab30
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2900C Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 08bb:29c0 class-ID: 0300
API: ALSA v: k6.10.1-2-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:08b1 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:4 chip-ID: 8087:07dc
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 sub-v: e00 hci-v: 6 rev: e00 class-ID: 6c0104
Info: acl-mtu: 1021:5 sco-mtu: 96:6 link-policy: rswitch hold sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 6.5 TiB used: 3.51 TiB (54.0%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T2IA temp: 40.9 C
ID-3: /dev/nvme2n1 maj-min: 259:11 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 49.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
serial: <filter> fw-rev: 2.22 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 1.12 TiB (62.0%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:9
used: 27.6 MiB (9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:8
used: 1.12 TiB (62.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:9
ID-1: swap-1 type: zram size: 15.53 GiB used: 10.54 GiB (67.9%)
ID-2: swap-2 type: partition size: 17.07 GiB used: 454.4 MiB (2.6%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:10
System Temperatures: cpu: 52.0 C mobo: 41.0 C gpu: amdgpu temp: 53.0 C
mem: 72.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 597
Memory: total: 16 GiB available: 15.53 GiB used: 7.98 GiB (51.4%)
Processes: 504 Power: uptime: 1d 15h 46m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: 2650 pm: pacman pkgs: 2611 libs: 634 tools: octopi,pacseek,paru
pm: flatpak pkgs: 39 Compilers: clang: 18.1.8 gcc: 14.1.1 alt: 13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: yakuake inxi: 3.3.35
System install date:     2024-05-15
Last full system update: 2024-08-02
~ Update ~
Ah it was cava-git due to it being pulse. problem solved. by removing it and building from source.
For the dummy noobs, what does that mean and how did you figure that out?
You can type the name of the conflicting file in terminal an see what depends on it. So in this case you can type either
paru -Qi pulseaudio or paru -Qi pipewire-pulse
Also when installing a application taking a mental note of dependencies it has is useful to.
Building it from source means going to its git an downloading an building it manually or following the build guide the author has posted.
