Pipewire module-native-protocol-tcp problem
Hello Garuda users.
A have a network audio problem, let me explain.
I was using the "pactl load-module module-native-protocol-tcp port=33478" command on my speaker pc so it was used as an audio receiver.
Next i used the command "pactl load-module module-tunnel-source channels=6 source_name=frmcstr server=tcp:192.168.2.112:33478" on my pc whitout any speakers and it worked perfectly for the past 3 month or so (thats when i set my PS's up, so after installing garuda).
It was creating an audio tunnel to my other pc, but now it no longer works i always creates a tunnel with one input on my non speaker pc, but too outputs on my speaker pc.
So i went looking but there was almost nothing at least i had no idea on how to solve it.
I waned to try the "PipeWire Module: ROC source" but that is not included in pipewire, maby the "module-rtp-send" cold work but i cold not get it to work.
So hope someone has a fix for this or can tell me how to make the "module-rtp-send" and "module-rtp-recv" work together with the cli.
here the garuda-inxi output as usual
╰─λ garuda-inxi
Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7c336077-248e-4bf2-8c6a-af5c3a83cfd4 rw [email protected]
resume=UUID=1b2a2c49-ae59-45a4-a5ab-e5faf0e5e217 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3004
date: 07/12/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1041 high: 3700 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 801 3: 800 4: 800
5: 800 6: 800 7: 3700 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 88796
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2482
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-14:5 chip-ID: 046d:082d
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 159 s-size: 613x352mm (24.13x13.86")
s-diag: 707mm (27.83")
Monitor-1: HDMI-0 res: 3840x2160 dpi: 160 size: 610x350mm (24.02x13.78")
diag: 703mm (27.69") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 3070
Ti/PCIe/SSE2 direct-render: Yes
driver: snd_hda_intel bus-ID: 1-14:5 v: kernel alternate: snd_soc_avs
chip-ID: 046d:082d bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:a2f0
serial: <filter> class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
Device-3: Logitech HD Pro Webcam C920 type: USB
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api tools: N/A
Device-2: Intel driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A
bus-ID: 03:00.0 chip-ID: 8086:093c class-ID: 0280
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-11:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 5.01 TiB used: 2.99 TiB (59.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA723020ALA641
type: HDD rpm: 7200 serial: <filter> rev: A840 scheme: MBR
model: WD30EZRZ-00GXCB0 size: 2.73 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 234.5 GiB size: 234.5 GiB (100.00%)
used: 44.44 GiB (18.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 234.5 GiB size: 234.5 GiB (100.00%)
ID-4: /var/log raw-size: 234.5 GiB size: 234.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 234.5 GiB size: 234.5 GiB (100.00%)
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 330 Uptime: 21m wakeups: 0 Memory: 31.28 GiB
used: 3.65 GiB (11.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1728
pm: pacman pkgs: 1705 libs: 446 tools: gnome-software,octopi,pamac,paru
pm: flatpak pkgs: 23 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date:     2023-02-18
Last full system update: 2023-04-25
So update i have changed literally all my network audio to rtp-send / rtp-recv it was a pain to get working and i had to google a lot but i made it mostly work.
How did I do it, well first used the
pactl load-module module-rtp-recv sink=reciveon latency_msec=50 sap_address=0.0.0.0
command to load the rtp receiver. Keep in mind that a sink with the name reciveon has to exist, the point of this is to first get rid of all audio send and than just handle the audio with with a script similar to qpwgraph. Than i have to check if my other PC is active for that i use
aw=1
while [[ $aw == 1 ]] #Wait for other pc to become active
do
    ping -W 1 -c 1 192.168.2.112 > /dev/null
    aw=$?
    sleep 5
done
After that I have to check if my audio connection is already there, for that i use
if [ $(pw-cli ls | awk '/node.name = "rtp_session.margamgar"/' | wc -l) == 0 ]
then
    pactl load-module module-rtp-send source=media.monitor destination_ip=192.168.2.112
    sleep 1
fi
if [ $(pw-cli ls | awk '/node.name = "rtp_session.margamgar"/' | wc -l) == 1 ]
then
    pactl load-module module-rtp-send source=them.monitor destination_ip=192.168.2.112
    sleep 1
fi
where margamgar ist the hostname of the other pc. For some reason it sometimes is not loading the receiver correctly at startup so i had to use
pactl unload-module module-rtp-recv
To reload the reciver. Finaly I use
./pipewire-script.sh load 2>/dev/null
this is my script for saving and loading pipewire connections, if you curious you can look at it and / or download it here: marvin1099/Pipewire-save-load: Unclean script to save and load your pipewire wires also name to id function is included since its nice to have. - Pipewire-save-load - Codeberg.org
The reason why a extra script and not qpwgraph is that it will conect all recivers to the same nodes since the have the same name, the script will just do the first result. There was something I had added to the script that was supposed to support occurrence but it is not working yet.
Also the rtp module cannot do more than 2 channels it seams so i have to create multiple senders. If you have a solution better than this its still wellcome.
