Hey there, thanks for the clarification, I will look around with this link you provided me, now I can at least have a clue about what’s going on, btw here is my garuda-inxi
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d34ff133-a363-46a3-ac0d-ecd7258f1611 rw rootflags=subvol=@
Mobo: ASUSTeK model: PRIME H510M-A v: Rev 1.xx
BIOS: American Megatrends v: 1017 date: 07/12/2021
Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFC
Speed (MHz): avg: 4000 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 69597
Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: eVga.com. driver: nvidia
v: 570.86.16 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2507
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
built: 2023 res: mode: 2560x1080 hz: 75 scale: 100% (1) dpi: 108 gamma: 1.2
size: 601x254mm (23.66x10") diag: 652mm (25.7") modes: max: 2560x1080
min: 640x480
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 driver: N/A device-ID: 10de:2507
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: eVga.com.
Device-3: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 03f0:078b class-ID: 0300
Device-4: Razer USA RZ04-0318 Gaming Headset [Kraken Ultimate]
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 1532:0527 class-ID: 0300
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api with: aoss
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Local Storage: total: 1.84 TiB used: 69.66 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X2001T
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-1: / raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
used: 69.66 GiB (7.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-3: /var/log raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-4: /var/tmp raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A
Memory: total: 32 GiB available: 31.19 GiB used: 7.14 GiB (22.9%)
Processes: 353 Power: uptime: 1h 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1850 libs: 562 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date: 2025-02-11
Last full system update: 2025-02-11
