Pinned Tabs not fixed anymore
Hi
since the update 3 or 4 days ago my pinned tabs are not fixed anymore.
which means if i have more tabs than can fit the tabbar the pinned tabs disappear to the right.
It happened after the update on both of my machines.
I am sorry I do not know exact versions but it was this week. 2nd to last update.
I’m currently on
11.17.6-1 (64-bit)
Just use more workspaces or allow more rows (works here).
Open issue on floorp, I think, Garuda can’t fix it :slight_smile:
grafik
I have tried for an hour to find something with “rows” in firedragon, I still have no idea how to do that.
the issue seems to be known in floorp though
