Hey folks, today I noticed that picom is taking about 15-25% (around 17% as of writing this) of cpu even when the pc is idle and nothing is open except htop.
I’ve searched around and all reports of picom taking too much cpu are cases of near 100% usage, in my cases its around 20% which isnt as big, but still a lot bigger than expected.
One fix that was proposed was to switch the backend to (or from) glx; neither helped so I retured it to the original value (xrender).
Any ideas?
root=UUID=b290f53a-a9c0-43d4-92d1-c19e8c49542f rw rootflags=subvol=@
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Razer product: Blade v: 6.06
Mobo: Razer model: Razer serial: <superuser required> UEFI: Razer v: 4.02
date: 02/22/2018
ID-1: BAT0 charge: 9.0 Wh (40.0%) condition: 22.5/70.2 Wh (32.1%)
volts: 12.2 min: 11.4 model: Razer Blade type: Unknown serial: <filter>
status: not charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 877 high: 923 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 899 3: 923 4: 800
5: 800 6: 898 7: 900 8: 901 bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: Razer USA driver: i915 v: kernel
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Razer USA
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20
Device-3: Realtek USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 0bda:579f
Display: x11 server: X.Org v: 21.1.9 compositor: Picom v: git-b700a
driver: X: loaded: intel,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x0569 built: 2016
res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1060 driver: nvidia v: 545.29.02
device-ID: 10de:1c20 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel CM238 HD Audio vendor: Razer USA driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 33.0 C
IF: wlp59s0 state: up mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
chip-ID: 0cf3:e300 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 476.94 GiB used: 68.14 GiB (14.3%)
model: MZVLW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: CXY7501Q temp: 36.9 C scheme: GPT
ID-1: / raw-size: 124 GiB size: 124 GiB (100.00%) used: 68.12 GiB (54.9%)
used: 27.6 MiB (28.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 124 GiB size: 124 GiB (100.00%)
used: 68.12 GiB (54.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 124 GiB size: 124 GiB (100.00%)
ID-5: /var/tmp raw-size: 124 GiB size: 124 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C pch: 46.5 C mobo: N/A
Processes: 236 Uptime: 6m wakeups: 0 Memory: total: 16 GiB
available: 15.51 GiB used: 2.11 GiB (13.6%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1787 libs: 450 tools: pamac,paru Shell: Bash
v: 5.2.15 running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2022-10-10
Last full system update: 2023-11-19
