Ello
8 October 2022 08:46
1
Hello i am new to garuda just installed it yesterday am dual booting it with windows the problem is everytime i try to update it gives me an error saying
"/var/cache/pacman/pkg/archlinux-keyring-20220927-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature))."
i would like to know how i could update to the latest pgp keys sorry for being stupid thanks
filo
8 October 2022 08:57
2
Hi there, welcome to the forum!
How do you update?
You should do that with
garuda-update
Try that first, if not already done, since it includes the main steps of the applicabile tutorial.
If you're getting an error similar to "Can’t update: signature from *** is marginal trust" or "invalid or corrupted package" you probably just need to update your package signing keys:
sudo pacman -Sy archlinux-keyring chaotic-keyring
sudo pacman -Syu
If you have added any other repositories, e.g. BlackArch, then add their keyring to the list.
Also make sure your system clock is correct!
Of course, it's also possible that the package file actually is corrupt. Remove it from /var/cache/pacman…
If not working, try deleting that file and update again as above.
TNE
8 October 2022 16:27
3
The quick fix solution to the problem you're having is trying garuda-update remote keyring, give that a shot!
Ello
9 October 2022 18:10
4
oh hey that worked thank you so much
system
Closed
11 October 2022 18:10
5
