Hi, laptop & desktop after :
sudo pacman -Syu
Import PGP key 0706B90D37D9B881, "Pedro Henrique Lara Campos <root@pedrohlc.com>"? [Y/n] n
ERROR: требуемый key miss в цепочке ключей
ошибка: не удалось завершить транзакцию (непредвиденная ошибка)
Обнаружены ошибки, пакеты не обновлены.
Don't update both.
What is the problem?
filo
23 June 2021 15:37
2
Please follow this tutorial:
If you're getting an error similar to "Can’t update: signature from *** is marginal trust" or "invalid or corrupted package" you probably just need to update your package signing keys:
sudo pacman -Sy archlinux-keyring chaotic-keyring
sudo pacman -Syu
If you have added any other repositories, e.g. BlackArch, then add their keyring to the list.
Also make sure your system clock is correct!
Of course, it's also possible that the package file actually is corrupt. Remove it from /var/cache/pacman…
bigAboo:
0706B90D37D9B881
Search also shows multiple existing threads:
https://forum.garudalinux.org/search?q=0706B90D37D9B881&expanded=true
system
Closed
25 June 2021 15:46
4
