Hi there Garuda people,
shortly after having installed Garuda, I wrote a post that became a very long thread about my impossibility to put the system in standby/sleep status.
Here is the original thread: Suspend/sleep not working - #107 by Ezahn
Thanks again and again to everybody that contributed! ![]()
I tried everyting, nothing worked, and then continued to search online for solutions that never worked (es. puttinc ACPI parameters in the kernel parameters).
At the time I even created a 16gb SWAP partition that never let me hybernate the system. And now, since many updates, I do not even see the hybernate option anymore.
After all those tries I just kept constantly updating the system with garuda-update, hoping that a new kernel or a new something would have fixed my sleep issues (at the time of my test live-usb it was working!): but no, nothing changed for the best until now.
Basically now:
- Iād like to remove the useless SWAP partition to reclaim space withou breaking anything;
- Iād like to know if it is worth it to keep trying and updating or If I must simply accept that my system will never sleep with Garuda (Iām dual booting and in W10 sleeps works); if thatās the case I will be forced to try another distro, even if I would really prefer to stay with Garuda, Iām loving it overall.
To make matters worse, at least one of my fans keep spinning constantly even when the PC is completely idle (in W10 as weel, thatās always been a problem, maybe it was assembled incorrectly) so not having a working sleep mode means hearing a fan all day long⦠^^
Hereās my actual inxi, btw:
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1930b164-e875-487b-9e15-d08dfb606021 rw rootflags=subvol=@
ibt=off resume=UUID=290da5e7-6510-4b46-9fa1-14463cba09cf
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Arch Linux
Type: Desktop Mobo: ASRock model: P67 Extreme4 serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: P3.10
date: 04/24/2012
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 1598 high: 1600 min/max: 1600/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1596
4: 1596 bogomips: 26341
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia
(as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DP-1,DVI-I-1 empty: DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 97 s-size: 503x283mm (19.80x11.14")
s-diag: 577mm (22.72")
Monitor-1: DP-1 note: disabled model: Panasonic Panasonic-TV
serial: <filter> built: 2010 res: 1920x1080 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") modes: max: 1920x1080 min: 640x480
Monitor-2: DVI-I-1 note: disabled pos: primary model: LG (GoldStar) W2363D
serial: <filter> built: 2011 res: 1920x1080 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 582mm (22.9") ratio: 16:9 modes:
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.276 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 545.29.06
device-ID: 10de:13c2 surfaces: xcb,xlib
vendor: ASRock 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: M-Audio AIR 192 6 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:3 chip-ID: 0763:410c
class-ID: fe01
Device-4: Logitech G430 Surround Sound Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 2-1.2:4 chip-ID: 046d:0a4d class-ID: 0300
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: b000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL88x2bu [AC1200 Techkey] driver: rtw_8822bu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:3
chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp4s0u2u2 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:4
Local Storage: total: 2.85 TiB used: 610.9 GiB (21.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX001-1NS164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT128M4SSD2
tech: SSD serial: <filter> fw-rev: 070H scheme: MBR
ID-1: / raw-size: 50 GiB size: 46.57 GiB (93.13%) used: 26.72 GiB (57.4%)
ID-2: /home raw-size: 414.91 GiB size: 414.91 GiB (100.00%)
used: 155.38 GiB (37.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 50 GiB size: 46.57 GiB (93.13%)
used: 26.72 GiB (57.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/tmp raw-size: 50 GiB size: 46.57 GiB (93.13%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
Memory: total: 16 GiB available: 15.58 GiB used: 7.67 GiB (49.2%)
Processes: 273 Power: uptime: 1h 12m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.17 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1493 libs: 489 tools: octopi,paru Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2024-01-27
Last full system update: 2024-02-25
Thanks for everything!
