Persistent Display Settings
Hey All!
I am new to Hyperland but have been using Garuda KDE for a while now. I am just now trying to do the switch to Hyperland and I am having some trouble with the whole modular config files.
I see that I can set my display settings using wdisplay, however they do not persist over reboot/Hyperland reset. I checked the hyperland config file and commented out the line because I saw that comment about commenting it out if you want to use your own monitor settings.
I also saw that you needed to write to a config file to make changes persistent however I am having trouble locating this config file particularly. I see that Kanshi is installed by default and was wondering if this is the write config file I should be writing to?
My issue is that I have two monitors that are stacked horizontal and I have no clue which config file to edit to make my wdisplay changes permanent.
Thanks again for your help!
Below is the garuda-inxi
  Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=d9426d1c-0b63-43a8-bbfd-96247749de54 rw rootflags=subvol=@
    quiet resume=UUID=826d4dc7-cfc9-4035-8ad4-b6d485ff691f loglevel=3
    nvidia_drm.modeset=1 ibt=off
  Desktop: Hyprland v: 0.40.0 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Desktop System: Gigabyte product: B650M AORUS ELITE AX v: N/A
  Mobo: Gigabyte model: B650M AORUS ELITE AX v: x.x
    Megatrends LLC. v: F20a date: 11/10/2023
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 926 high: 5489 min/max: 400/5733 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3776 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 4569 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    23: 5489 24: 400 bogomips: 225183
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
    off: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2484
  Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
    DP-6, HDMI-A-2, Writeback-1 bus-ID: 10:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 44.0 C
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.2:3
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
    compositor: Hyprland v: 0.40.0 driver: X: loaded: amdgpu,nvidia
    gpu: nvidia,nvidia-nvswitch d-rect: 5360x2520 display-ID: 1
  Monitor-1: DP-1 pos: bottom-l model: Dell U3417W serial: <filter>
    built: 2016 res: 3440x1440 hz: 60 dpi: 109 gamma: 1.2 scale: 1
    size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
    min: 640x480
  Monitor-2: DP-2 pos: top-right model: LG (GoldStar) ULTRAGEAR
    serial: <filter> built: 2021 res: 1920x1080 hz: 165 dpi: 70 gamma: 1.2
    scale: 1 size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3070 driver: nvidia v: 550.78 device-ID: 10de:2484
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
    v: 24.0.7-arch1.3 device-ID: 1002:164e surfaces: xcb,xlib,wayland
    device: 2 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits)
    driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM 17.0.6)
  Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: C-Media Q9-1 driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.2:6
    chip-ID: 0d8c:0135 class-ID: 0300
  Device-5: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0
  IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0c:00.0
  IF: wlp12s0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 0b05:190e
  Device-2: Intel AX210 Bluetooth driver: N/A type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0032
    class-ID: e000
  Local Storage: total: 3.64 TiB used: 17.29 GiB (0.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Netac model: MobileDataStar
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A
    serial: <filter> fw-rev: 0209 scheme: MBR
  ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 17.29 GiB (0.9%)
    used: 17.29 GiB (0.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 33.54 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 59.5 C mobo: 34.0 C gpu: amdgpu temp: 45.0 C
  Memory: total: 32 GiB note: est. available: 30.49 GiB used: 3.47 GiB (11.4%)
  Processes: 431 Power: uptime: 27m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.16 GiB services: upowerd Init: systemd
    v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1387 libs: 455 tools: pacseek,paru Compilers:
    gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
    inxi: 3.3.34
  System install date:     2024-05-23
  Last full system update: 2024-05-23 ↻
You’re going to need the Hyprland wiki, especially the part on Configuring Hyprland states that the config is located in
~/.config/hypr/hyprland.conf
The monitors section has all the details on how to edit the monitors section. wdisplays is great for visually setting the monitors how you want them and reading the values to plug into the conf file.
Monitors – Hyprland Wiki
I have monitors in Hyprland set up to my liking and I’ve never touched Kanshi.
