PC wont boot after power outage
When it passes the inital selection screen it pops up what is below.
I have tried for an hour and a half to fix it but nothing online I can find is helping and I’m not good at computer code stuffs please help
[Failed] failed to start Simple desktop display manager
[Failed] failed to start samba nmb daemon
[Failed] failed to start samba smb daemon
Sometimes when my boot up fails or hangs, it miraculously continues if i press enter.
For more help, we need the garuda-inxi information.
Tried several different fixes I found on here for the individual failures but none worked
I entered that command and a lot of info popped up what specifically did you need?
Use last working snapshot.
For garuda-inxi you can use live ISO too.
I attemped to return to the previously working snapshot but the scrolling text freezes up midway through. And im unsure what you mean by Live iso, apologies im not well versed :downcast_face_with_sweat:
If i could send a picture of it i would
I had to return to one of the very last saved snapshots I had and that booted up.
Thanks for the help
