Hello I am using Garuda for 3 months now and been happy so far but when I updated linux-mainline 5.13 to 5.14rc1-1 I get errors with nvidia-dkms when installing the kernel so I searched and found this:
nvidia-fix-linux-5.14.patch
From f18c541edc5e122b06b0c1e65d0a422f0b8109e7 Mon Sep 17 00:00:00 2001
Date: Fri, 2 Jul 2021 02:09:58 +0200
Subject: [PATCH] Tentative fix for NVIDIA 465.31 driver for Linux 5.14-rc1
common/inc/nv-time.h | 6 ++++++
nvidia-drm/nvidia-drm-drv.c | 4 ++++
2 files changed, 10 insertions(+)
This file has been truncated. show original
the problem I have is that I don't know how to patch the nvidia-dkms driver
I hope you can help me
The mainline kernel is only experimental as you are probably aware, issues are to be expected when running this kernel. Unless your hardware is extremely new another kernel may be a better fit. However, there is no way for us to know that as you did not provide your system specs with a inxi -Faz output.
Welcome to the forum.
But the Packager would know.
$ LANG=en pacman -Si nvidia-dkms | grep -E "^Version|^Packager|^Build"
Version : 465.31-1
Packager : Sven-Hendrik Haase <svenstaro@gmail.com>
Build Date : Tue May 18 20:47:23 2021
╰─λ inxi -Fza
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=44fdce15-2a62-4998-9199-f970695363ad rw rootflags=subvol=@ quiet splash
resume=UUID=ef22100c-df8f-4c7e-9d23-450d77e09d01 loglevel=3
Desktop: LXQt 0.17.1 tk: Qt 5.15.2 info: cairo-dock, lxqt-panel wm: kwin_x11 vt: 1
Machine: Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <filter>
UEFI: American Megatrends v: P4.50 date: 03/12/2021
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86404
Speed: 3596 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3596
2: 3630 3: 3454 4: 3652 5: 3606 6: 3600 7: 3514 8: 3609 9: 3600 10: 3597 11: 3601
12: 3598
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:1b81
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5")
s-diag: 600mm (23.6")
Monitor-1: DP-2 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA Gaming Controller [Raiju] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:5 chip-ID: 1532:1000
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock
driver: r8169 v: kernel port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 1.47 TiB used: 613.02 GiB (40.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS547550A9E384 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: A50B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Drevo model: X1 SSD size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2A
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000LM010-9YH146
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: CC9F scheme: GPT
Partition: ID-1: / raw-size: 94.43 GiB size: 94.43 GiB (100.00%) used: 30.69 GiB (32.5%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 6.7 MiB (2.7%)
fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 94.43 GiB size: 94.43 GiB (100.00%) used: 30.69 GiB (32.5%)
ID-4: /var/log raw-size: 94.43 GiB size: 94.43 GiB (100.00%) used: 30.69 GiB (32.5%)
ID-5: /var/tmp raw-size: 94.43 GiB size: 94.43 GiB (100.00%) used: 30.69 GiB (32.5%)
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
ID-2: swap-2 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 58.1 C mobo: N/A gpu: nvidia temp: 61 C
Info: Processes: 288 Uptime: 3h 59m wakeups: 0 Memory: 15.55 GiB used: 3.06 GiB (19.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1383
lib: 406 Shell: fish v: 3.3.1 running-in: alacritty inxi: 3.3.05
@NoName1337
If you include terminal outputs in your post, please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
I much happier with 5.13 Cacule. I will test 5.14 rc2 later today with the new dkms driver. hopefully it works.
thank you both for your help and time
system
Closed
23 July 2021 04:07
7
