PasswordSafe (pwsafe) simply does not work
If this is a thing that requires scripting to fix, I am very screwed.
This issue is happening with PasswordSafe (pwsafe) as said in the title…
I simply can never open it. It just won’t let me. The first try (using flatpak), it did this.
Second try with the AUR installs, it still did this.
Using sudo worked for a short while to get it working but it eventually died too.
The error:
/usr/include/c++/14.1.1/bits/stl_vector.h:1130: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::operator[](size_type) [with _Tp = std::__cxx11::basic_string<wchar_t>; _Alloc =std::allocator<std::__cxx11::basic_string<wchar_t> >; reference = std::__cxx11::basic_string<wchar_t>&; size_type = long unsigned int]: Assertion '__n < this->size()' failed.
fish: Job 1, 'pwsafe' terminated by signal SIGABRT (Abort)
garuda-inxi:
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=cd554b12-50c1-4d21-8dc3-75e81b1e0163 rw rootflags=subvol=@
intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: HP ZBook 17 G3 v: N/A
Mobo: HP model: 80D6 v: KBC Version 10.75 serial: <superuser required>
part-nu: 1MY26EC#ABA uuid: <superuser required> UEFI: HP v: N81 Ver. 01.45
date: 01/06/2020
ID-1: BAT0 charge: 35.8 Wh (49.2%) condition: 72.7/72.7 Wh (100.0%)
volts: 11.2 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-6440HQ bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 2616 high: 2849 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2835 2: 2250 3: 2532
4: 2849 bogomips: 20799
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM204GLM [Quadro M3000M] vendor: Hewlett-Packard
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-4,DP-5,DP-6
bus-ID: 01:00.0 chip-ID: 10de:13fa class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-7:2 chip-ID: 05c8:0383 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1738 built: 2015 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 15.14 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu
name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:191b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: Quadro M3000M driver: nvidia v: 550.78 device-ID: 10de:13fa
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM 17.0.6)
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Hewlett-Packard
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 8087:0a2b
Local Storage: total: 1.14 TiB used: 420.04 GiB (35.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: THNSN5256GPUK
NVMe TOSHIBA 256GB size: 238.47 GiB block-size: physical: 512 B
fw-rev: 5KDA4103 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3T0 scheme: GPT
ID-1: / raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
used: 35.87 GiB (15.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 264 MiB (51.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 383.91 GiB (41.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C pch: 53.0 C mobo: N/A
Memory: total: 16 GiB available: 15.5 GiB used: 3.15 GiB (20.3%)
Processes: 285 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: 2406 pm: dpkg pkgs: 0 pm: pacman pkgs: 2364 libs: 593
tools: octopi,paru,yay pm: flatpak pkgs: 42 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date:     2023-07-21
Last full system update: 2024-05-18
Relevant software:       snapper NetworkManager dracut(custom) nvidia-dkms
The last update of that AUR package was in March 2022.
The last commit upstream 3 years ago.
I think a breakage can happen in these cases.
In my opinion you’d better look for an alternative.
Wrong one. I was talking about the passwordsafe package.
Just added the “(pwsafe)” to clarify that the application was the one that uses that command name/URL was the one I was talking about, and not the other Password Safe.
(Definitely caused confusion there. Oops.)
Hmm… Should I attempt to edit the initial post in order to make it clear WHAT I’m trying to fix, due to the initial miscommunication?
Actually, I think I should make a new post. Pretty sure nobody’s going to actually really go here and try to help, due to said miscommunication.
Well, I’ll try and wait until the 14 days are over BEFORE creating a new post.
I have already adjusted it, and if no one here can help in the next 14 days, it won’t help to adjust it again.
Have you already asked the developer?
He is also the only one who can fix bugs there.
BTW, this forum is not a general technical support forum. :slight_smile:
