Passwords will not work in succession after being typed correctly; tested on multiple systems; only happens after system updates. Leaving machine off; using the computer; clears the memory enough to fix the issue after a few minutes.
Much appreciated.
Kernel: 6.5.7-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm parameters: pti=on
root=UUID=ee9d8e46-88f6-40bb-a345-3b374ebb4edb rw rootflags=subvol=@
quiet rd.luks.uuid=5d766ada-bbea-4479-b984-c5950293753b quiet
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: A88XM-PLUS v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3004
date: 04/14/2017
Info: model: AMD A10-7850K Radeon R7 12 Compute Cores 4C+8G bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3624 high: 3879 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3323
3: 3595 4: 3879 bogomips: 29539
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: XFX Pine
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:687f
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 358x202mm (14.09x7.95")
s-diag: 411mm (16.18")
Monitor-1: DP-3 mapped: DisplayPort-2 model: Sharp HDMI built: 2008
res: 1360x768 hz: 60 dpi: 42 gamma: 1.2 size: 820x460mm (32.28x18.11")
diag: 940mm (37") ratio: 16:9 modes: max: 1920x1080 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (vega10 LLVM
16.0.6 DRM 3.54 6.5.7-hardened1-1-hardened) device-ID: 1002:687f
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.264 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:687f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aaf8 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i2 3rd Gen
driver: snd-usb-audio,usb-storage type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 2-3:4 chip-ID: 1235:8210 class-ID: 0806
API: ALSA v: k6.5.7-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.14 TiB used: 104.78 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 3B0Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdc maj-min: 8:32 model: Scarlett Welcome Disk size: 192 KiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 0.10 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Transcend model: N/A size: 1.87 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: TS37
scheme: MBR
ID-1: / raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
used: 23.33 GiB (9.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5d766ada-bbea-4479-b984-c5950293753b
ID-2: /home raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-3: /var/log raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 15.5 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 24.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 414
Processes: 252 Uptime: 35m wakeups: 0 Memory: total: 32 GiB
available: 31.3 GiB used: 2.68 GiB (8.6%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1440 libs: 470 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-03-11
Last full system update: 2023-10-14 ↻
