Password for drive encryption not being asked/nor admin password
Hello… I used Garuda XFCE for a few months on my old machine and got a new computer and installed it on there. Great experience. I downloaded and sha256 checksum’d the download before flashing with etcher. Upon installing I checked the encryption option and I did not set a different admin password. System does not ask for the encryption password as it did on my previous machine. I had to install a diff operating system to install grapheneos so I did and tried to install Garuada XFCE again thinking perhaps I unchecked the box in the first install, this time making sure I checked the encryption box but also set an admin password this time.
Still not asking for my encryption password, doesn’t ask for my admin password in the terminal. System only asks for my log in password and I use it in lieu of the admin password I set as well.
I’m not sure what else I need to say.
  Kernel: 6.6.54-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=56be821f-e904-4de1-b16f-0ded8f7aed7e rw rootflags=subvol=@
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Type: Desktop System: HP product: HP Pavilion Desktop TP01-2xxx v: N/A
  Mobo: HP model: 8906 v: SMVB serial: <superuser required>
    part-nu: 318G6AA#ABA uuid: <superuser required> UEFI: AMI v: F.32
    date: 03/27/2024
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000F
  Speed (MHz): avg: 1400 min/max: 1400/3800 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 121410
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    active: HDMI-A-1 empty: DP-1 bus-ID: 0c:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 23.0 C
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Lenovo Q24i-1L
    serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
  API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.4-arch1.1
    device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.4-arch1.1 (LLVM
    Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.1
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.6
  API: ALSA v: k6.6.54-1-lts status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
  IF: wlp9s0 state: down mac: <filter>
    lanes: 1 port: d000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:3 chip-ID: 0bda:b00e
  Local Storage: total: 953.87 GiB used: 20.58 GiB (2.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: BC901 HFS001TEJ9X108N size: 953.87 GiB block-size: physical: 512 B
    fw-rev: HPS2 temp: 24.9 C scheme: GPT
    used: 20.57 GiB (2.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 14.96 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 25.0 C
  Memory: total: 16 GiB note: est. available: 14.97 GiB used: 5.36 GiB (35.8%)
  Processes: 395 Power: uptime: 1h 29m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.98 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1438 libs: 447 tools: paru,trizen Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.36
  System install date:     2024-10-06
  Last full system update: 2024-10-06
  Failed units:      ```
